Corel real de france Build Log
User avatar
Seafever
Petty Officer First Class
Postby Seafever » Wed Feb 01, 2012 11:36 pm
Hi ,I'm Reggie . I am from MA . And live on an Island .I have been following Ships of Scale for a few months now . Donnie I appreciate what you have done here and want to Thank you . I am currently building Real de France by Corel . here is my build Log so far . I will show some things I have finished so far . Presently I am working on the outer walkways . I started doing the inlay of the rear decking . and building the gun carriges .I will post those photo's when I get some time . I need help deciding what to do about the around 120 Drains in the deck . each one is shaped like this "{] " ! I decided to hold off for now till I do more research .
This is the hull after two layers of planking , Lime wood then walnut .I also added some yellow wood for the trim pieces .
Photos 2011-12 113.JPG (88.85 KiB) Viewed 5698 times
Here are the over 100 frames for the deck that had to individually cut out and shaped
Photos 2011-12 059.gif (107.77 KiB) Viewed 5698 times
I used the walkway frames to line up the seats as I cut and shaped all 59 of them .
january192012 003.JPG (104.35 KiB) Viewed 5698 times
They want me to cut over 100 holes shaped like this { into the deck . I am debating . I don't want to mess up . Anyone have any ideas how to do this safely let me know .
january192012 007001.jpg (48.05 KiB) Viewed 5698 times
Here is the kit contents
these are the phot etched decorations
These are the brass ornaments
These are the 59 Oars Not 60 because there is a fire pit on Board
This is the deck I had to file each slot after planking it to fit the Frames
This is the box art with this version of the kit another version has the oars in plastic bags I found out .
Current build Corel Real de France
User avatar
Sjors55
Chief Petty Officer
Chief Petty Officer
Re: Corel real de france Build Log
Postby Sjors55 » Thu Feb 02, 2012 2:33 am
Welcome to SoS Reggie,
You are here at the right adress for such questions.
I can not answer your questions because I'm a rookie myself... :)
Your kit is impressive.
Is all the wood so individually wrapped?
Your planking is great,nice and clean.
Keep posting and we enjoy.
Sjors :auto-driving:
Whatever you do will be insignificant, but it is very important that you do it.
(Mahatma Gandhi)
Current build:
Le Mirage by Corel (1:75)
Current build: San Ildefonso by OcCre (1:70)
viewtopic.php?f=52&t=279
User avatar
wim500
Petty Officer Second Class
Postby wim500 » Thu Feb 02, 2012 4:18 am
Welcome Reggie :D .
This is really a nice ship.
To help you with the 100 holes in the deck I think we need a better pic.
It is difficult for me to see what you exactly mean.
Good luck.
Regards,
Wim
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Thu Feb 02, 2012 10:44 am
Hello Reggie,
Welcome tot S0S.
It's indeed a very nice looking galley. Seems like a lot of work?
Looking forward to your progress. Have fun with the build.
Anja :happy-sunshine:
Those we loved but lost are no longer where they were,
but are always where we are.
Current build - De Halve Maen by Corel
viewtopic.php?f=52&t=235
Completed : Albatros 1840 by Constructo
User avatar
Donnie
Senoir Chief Petty Officer
Contact:
Postby Donnie » Thu Feb 02, 2012 11:45 am
Hi Reggie -
WOW - now this is an awesome kit !
I wish I could see either the plans or a portion of the instruction manual so that I can see a little better what is needed here. It can be daunting task.
I can understand your hesitancy as I am sure that you want to make all those openings the same. Perhaps if you had some plain masking tape. Maybe you can lay the masking tape along what seems to be the upper wales. Then I would pencil in or darken the area of each hole. I would start with a small drill (usually called a pinvise) and start your hole that way. I would not use a power tool at this point.
Let me know how else I can help. Popeye might have an idea too.
Don't give up.
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
User avatar
wim500
Postby wim500 » Thu Feb 02, 2012 12:19 pm
Hello,
With the additional info of Donnie and his remark about the masking tape I presume you have to drill tho holes for the oars.
Then masking tape is perfect. I used that during the build of the Nave Egizia.
First I made all the marks on the tape, then I placed the tape on the hull and you can start drilling.
See the picture:
Good luck :D
Regards,
Wim
User avatar
Seafever
Postby Seafever » Fri Feb 03, 2012 12:31 am
I appreciate all the help ! This is really mostly not that difficult a model to do.It's actually a lot of fun because it is so diiferent . It's just there are difficult parts it needs a lot of very accurate work and you need to put up with making 59 or 120 of each part which gets a bit old . I found you have to be very careful with the sanding of the second layer of Walnut it is only 1x4 mm and I hand sand and sanded it through and had to remove planks and redo them .
I am doing the Drains they are very small and shaped like 2 U's UU . I Love all the ideas . I will have to post the plans and the directions ( hard to understand at times )
I Like the idea of using Masking tape I use Masking tape when I install electronics and Control boxes in real Boats . I trace the pattern with Carbon Paper onto the hull and carefully cut it out . These holes are very small about 1/16- 1/8 of an inch wide .
I'll take some more photos and post ! Thanks again ! I'm sure anyone on here can build this Model .Your Models are way more Clean than Mine is .
User avatar
Seafever
Postby Seafever » Fri Feb 03, 2012 12:47 am
I just wanted to mention as far as the wood goes only the wood oars are in plastic cases . The other wood is in plastic bags in the box and has rubber bands at each end . Also there are 3 inlayed pieces for the rear deck and the sides . The delicate pieces are kept together with larger pieces and the plans are laid out in numerical order . You build Step By Step in order or you could get into a mess . I actually had to number the frames with a pencil to keep track of the over 100 pieces and sand it off as I installed them .Some of them didn't fit right and had to be modified .One thing about this model you have to be careful you don't make a major mistake that would be difficult and near to impposible to fix without starting over . My Rectangular inlayed squares for the rear deck were to large so I had to modify the Layout . I'll Post this later . :greetings-waveyellow:
User avatar
Seafever
Postby Seafever » Fri Feb 03, 2012 1:59 am
Ok here are the Photos of the plan and the Directions :text-coolphotos:
Also I pointed out just where the holes need to be cut out . I hope you have a better idea of what is going on here Now ! :text-thankyouyellow:
The Model Page one
2212 016.JPG (134.52 KiB) Viewed 5674 times
The Stern View Close up
2212 013.JPG (120.03 KiB) Viewed 5674 times
The center
2212 010.JPG (91.47 KiB) Viewed 5674 times
The Bow Section
2212 012.JPG (112.57 KiB) Viewed 5674 times
The Instructions Very Simple
2212 018.JPG (78.14 KiB) Viewed 5674 times
Exactly what holes need to be cut out
2212 0101.jpg (98.5 KiB) Viewed 5674 times
User avatar
Seafever
Postby Seafever » Fri Feb 03, 2012 2:01 am
:text-thankyouyellow: The Diagram in that photo is about 4 feet wide! :text-woo:
Who is online
Users browsing this forum: No registered users and 2 guests
