Constructo Albatros 1840
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Mon Jan 30, 2012 2:15 pm
Hello everybody,
Albatross, originally named Albatros, was a sailing ship built as a schooner at the state shipyard in Amsterdam, Netherlands in 1920, to serve as a pilot boat in the North Sea.
The slender shape of the hull and the relatively smooth lines of the deck were copied from the French frigates, which frequently sailed into ports on the American coasts during the war of indepence.
The first schooners which were built in Baltimore quickly established themselves on both coasts of the USA and later in other areas as well. On the west coast they were used for carrying timber and on the east coast mainly for ship coal.
Scale 1:55
Length 510mm
Height 390mm
Width 160mm
Albatros Constructo.JPG (44.58 KiB) Viewed 7946 times
Parts and manual.JPG (29.61 KiB) Viewed 7946 times
Contents of the box.JPG (46.18 KiB) Viewed 7946 times
Anja :happy-sunshine:
Those we loved but lost are no longer where they were,
but are always where we are.
Current build - De Halve Maen by Corel
viewtopic.php?f=52&t=235
Completed : Albatros 1840 by Constructo
User avatar
wim500
Petty Officer Second Class
Re: Constructo Albatros 1840
Postby wim500 » Mon Jan 30, 2012 3:24 pm
Good luck with this beauty :D .
Pay extra attention to the bullwarks :lol: .
Regards,
Wim
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Tue Jan 31, 2012 10:36 am
A little progress,
The frames are in place, but not glued yet. So, back to work.
Dry fit bulkheads.JPG (23.17 KiB) Viewed 7932 times
User avatar
popeye
Master Chief Petty Officer
Contact:
Postby popeye » Tue Jan 31, 2012 11:51 am
looking good so far....your going to have quite a ship yard! :D
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
User avatar
Sjors55
Chief Petty Officer
Chief Petty Officer
Postby Sjors55 » Tue Jan 31, 2012 2:11 pm
I know that for sure Popeye.
And you know what?
She is more upstairs then in the livingroom :)
But she loves it, so it is no problem.
Whatever you do will be insignificant, but it is very important that you do it.
(Mahatma Gandhi)
Current build:
Le Mirage by Corel (1:75)
Current build: San Ildefonso by OcCre (1:70)
viewtopic.php?f=52&t=279
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Tue Jan 31, 2012 3:51 pm
My progress so far.
The frames are glued in place on the false keel. The stem wedges are also in place. After making sure the lower formast and the lower mainmast fitted in their corresponding drill holes on deck, the deck was glued on and secured with rubber bands (no tie rips at hand) and tacks. The tacks I will remove after the deck has dried.
Next on the to-do list: Filing the edges of the frame, keel and stem wedges to ensure a good fit for the hull planking. The Albatros has a plank-on-bulkhead construction.
Making sure that the frames are straight.JPG (34.88 KiB) Viewed 7925 times
The masts fits, so the deck can be glued.JPG (23.13 KiB) Viewed 7925 times
Wedges in place, deck glued.JPG (27.04 KiB) Viewed 7925 times
Side view.JPG (27.35 KiB) Viewed 7925 times
User avatar
popeye
Contact:
Postby popeye » Wed Feb 01, 2012 8:58 pm
it's looking good so far Anja. yes....faring the hull will be next.
you know what I just noticed.......you have a plastic assortment case in the background of some of your pictures........I have the same one!!! I keep my paints in it. how cool is that???
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Thu Feb 02, 2012 11:06 am
Hi Popeye.
The plastic assortment case is indeed very cool. Mine is still empty, because I just stole it from Sjors's fish bag :o
He doesn't know yet, so don't tell him :lol:
The fairing is done, and I started with the hull planking. But I'm having a hard time fitting the planks.
As I said earlier, the Albatros has a plank-on-bulkhead construction. So the planks are a bit thicker and not so easy to bend (not even when they're wet).
So I try to let the planks (if possible) find their place on the hull by themselves. At the bow the planks has to go a little higher, so they stick out over the bow.
Does this make any sense? Hopefully tonight I can post some picture!
PS - I'm talking about what I did, but of course I mean what WE did ( :text-imsorry: Sjors)
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Thu Feb 02, 2012 3:43 pm
My progress so far.
I used tacks, because the pushpins were too long and too thick to use.
I tried clamps to hold the planks in place, but they kept slipping of the frame.
When the hull planking is done the tacks will be removed and a little water put in each hole to make the wood swell up and hide the holes as much as possible.
The bow looks oké. When the planks are filed/sanded it ends up just in the center where the keel has to be placed. That's a good thing.
I've gone through the tutorial 'Simple hull planking for beginners'.
But unfortunately I did made the mistake of not faring the hull correctly at the starboard side of the stern. As you can see in pictures 3 & 4.
First plank in place. So far, so good..JPG (32.62 KiB) Viewed 7905 times
This is all you need to hold a plank in place.JPG (37.7 KiB) Viewed 7905 times
Bow view - Little damage on the upper plank.JPG (27.5 KiB) Viewed 7905 times
Star board view - Not faired correctly.JPG (36.77 KiB) Viewed 7905 times
Next on the to-do list: Completing the hull planking, restoring the errors I've made to ensure a smooth hull.
User avatar
Donnie
Senoir Chief Petty Officer
Contact:
Postby Donnie » Sat Feb 04, 2012 11:38 pm
Wow - Anja - Hummm - I think you must have some shipyard experience in yer blood ??
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
Who is online
Users browsing this forum: No registered users and 2 guests
