HMS SKIRMISHER 1/96 Deans Marine kit
User avatar
GeeJay
Petty Officer Third Class
Postby GeeJay » Tue Aug 16, 2016 5:23 am
Hi folks I'm going to make a start on this new kit mainly because I need to get it to the stage of installing the electrics so I can make sure the radio stuff works.
I am still working on the Vic too and will update that log soon
Happy Day's
GrahamJ
Building, HMS Victory
In the queue, HMS Skirmisher.
User avatar
GeeJay
Re: HMS SKIRMISHER 1/96 Deans Marine kit
Postby GeeJay » Tue Aug 16, 2016 5:51 am
So lets see what we have in the box then.
Basically we have a fibreglass hull with a variety of plastic printed sheets,(No Die cutting in this kit) a selection of cast white metal and cast resin parts in trays. a few strips of Balsa and Ramin and the included running gear (props/rudder/tubes etc.).
And of course plans/instructions. this is definitely not a beginners kit and is bordering on being a scratch build. All the cast parts are rough cast which means a lot of work is required before you can use any of them. The plans/instructions are far from ideal and leave a lot to you own interpretation of what it should be like.
Happy Day's
GrahamJ
User avatar
GeeJay
Postby GeeJay » Tue Aug 16, 2016 6:09 am
And a few things that were not in the box.
Happy Day's
GrahamJ
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Postby eric61 » Tue Aug 16, 2016 8:12 am
Hi Graham, the little building in the background would make suit a diorama quite nicely.
Eric
Cook's Endeavour - current,
Sovereign of the Seas - current (deAgostini)
In queue: Marina II Fishing Boat by Artesania Latina
In queue: Mayflower by Model Shipways
"I was thinking then it all went blank!"
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Tue Aug 16, 2016 3:39 pm
I have never seen a Deans Marine kit before, but this looks like it will make a nice radio controlled model. With so much of everything being made for you, the key to how it turns out will be the paint job. Time to get out the small brushes and magnifying glasses.
Should make a quick and interesting build.
Good luck.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
Aussie048
Petty Officer Second Class
Postby Aussie048 » Tue Aug 16, 2016 11:07 pm
Graham
I am looking forward to see progress on you build. I have never seen the Deans kit before, so very interested
Cheers
Geoff
Current Build Link:-
Mamoli - USS Constitution
***Live , Listen and Learn***
User avatar
GeeJay
Postby GeeJay » Wed Aug 17, 2016 11:43 am
Thanks for the comments folks, if you want to take a look at Deans then try this.
http://www.deansmarine.co.uk/shop/
First job was to clean the hull up a bit and drill a few holes and strengthen it.
next job will be to install all electrics/props and rudder then drill all those portholes 40+.
a few pics to follow.
Happy Day's
GrahamJ
User avatar
GeeJay
Postby GeeJay » Thu Sep 01, 2016 1:12 am
Ok onto the build.
First steps to put some support into the hull.
Happy Day's
GrahamJ
User avatar
GeeJay
Postby GeeJay » Thu Sep 01, 2016 1:17 am
Ok onto the build.
Happy Day's
GrahamJ
User avatar
GeeJay
Postby GeeJay » Thu Sep 01, 2016 1:23 am
Mark and drill holes for the props and rudder assemblies.
Prop A Frames tacked into position.
Rudder tube tacked into position too.
Happy Day's
GrahamJ
Who is online
Users browsing this forum: No registered users and 1 guest
