USS Constitution "Old Ironsides " 1:93 Scale Mamoli
User avatar
Canoe21
Petty Officer Second Class
Contact:
Re: USS Constitution "Old Ironsides " 1:93 Scale Mamoli
Postby Canoe21 » Sat Apr 01, 2017 4:42 pm
Aussie048 wrote:Well now I am on a role I thought we might get onto making the bow block fillers
Cutting out the bow blocks and shaping
Dry fitting the bow blocks
Fitting the bow blocks. I find rubber bands are grat the you don't have a flat surface to clamp with
Finally the bow block have been fitted and the faring on them is complete
Hello Geoff
Nice to see that your Connie is back in your Old Ship Yard and that you are making great progress, ENJOY.
Regards Lawrence
canoe21 { Lawrence }
PRESENT BUILD - viewtopic.php?f=59&t=1221 - GOLDEN HIND< Harold A. Underhill build plans, scale 1:60
Completed Build viewtopic.php?f=59&t=1172 HMS Bounty, scratch build, scale 1:60, using Amati build plans
User avatar
Aussie048
Petty Officer First Class
Postby Aussie048 » Sat Apr 01, 2017 5:31 pm
Lawrence
Nice to see an old buddy down here. The Connie is much further advanced and I am still catching up on the build log, very slowly.
You will find a loot of members down here that you probably know
Cheers
Geoff
Current Build Link:-
Mamoli - USS Constitution
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
***Live , Listen and Learn***
User avatar
Aussie048
Postby Aussie048 » Sat Apr 01, 2017 5:54 pm
Gemma
It comes from a spay can. I think it is probably easier to handle by just having to shake the can than to mix.
I have been reading through your build log of the Black Pearl, but am in the early stages and yet to comment
One of our friends is also working on a ZHL kit which I will be seeing later this morning. He is the one who came up with the idea and has used it on most of his builds if not all. I am impressed with the quality of the timber of the ZHL. He is the best one to explain the process. I'm pretty sure you know who I am talking about.
We are going to look at deck planking for my Connie as I have been advised very strongly not to use the Tanganyika that was supplied in the kit
Cheers
Geoff
On Hold Builds:-
Santa Maria
Member
User avatar
GemmaJF
Postby GemmaJF » Sat Apr 01, 2017 6:00 pm
Hi Geoff,
I think I know who you mean ;-)
If your kit Tanganyika is anything like the replacement wood I bought for my Black Pearl build, you may be well advised not to use it! I only carried on with it because the Pearl is supposed to be a bit rough around the edges, on a more serious build it would have been of little use at all.
Current Build: ZHL Black Pearl 1:50
Next Up: Billing Boats Bounty 1:50
Researching for POB scratch build : HMS Ferret 1:48 (1711)
Projects: Arduino Lighting Project
User avatar
Aussie048
Postby Aussie048 » Sat Apr 01, 2017 10:23 pm
We came up with some cherry to replace the Tanganyika with.
It is a lot lighter than Tanganyika I have which was more orange in colour but I have seen some different shades of Tanganyika which vary a lot.
Cheers
Geoff
On Hold Builds:-
Santa Maria
Member
User avatar
DenisR
Postby DenisR » Tue Apr 04, 2017 1:47 am
Hi Geoff
Build is looking very nice well done.
Good move to change the Tanganyika deck planking over to Cherry, I wish I had done the same with my Revenge build.
Denis.
User avatar
Aussie048
Postby Aussie048 » Fri Apr 07, 2017 5:08 pm
Hi Denis
Thanks for being so adamant that I was not to use the Tanganyika for deck planking.
I must also thank Brian for sourcing the Cherry for me. I hope I can do it justice and sure I will.
The thing I like the most on SOS is seeing old mates and meeting new ones in a very friendly environment.
Sharing advice, advice is free.
My goal is to get my build log up to date before the end of the month and then start building again. :D
Cheers
Geoff
On Hold Builds:-
Santa Maria
Member
User avatar
DenisR
Postby DenisR » Fri Apr 07, 2017 8:17 pm
Hi Geoff
I don't think you will regret using the Cherry.
Also a thank you to Brian for helping you out.
Denis.
User avatar
Aussie048
Postby Aussie048 » Thu Apr 13, 2017 2:21 am
Well time for the next update to catch up the build log with the actual build. I do hope I am building again late next week. :D
It was time to dry fit and install the false deck
Well I had an issuewith the false deck. The false deck goeds upward from this point. My clamps were all to large so it was time to make a clamp up. I went through my junk box that has all the little bits and pieces in it that you should never throw out and made a clamp
Problem solved with a bit of scrape glued underneath the issue All fixed.
On Hold Builds:-
Santa Maria
Member
User avatar
Aussie048
Postby Aussie048 » Thu Apr 13, 2017 3:18 am
The next step was to fit the lower gun ports. I needed to use epoxy resin OOPS I am allergic to that stuff. Eye lids get real red around the eyelids forehead got scaly. Down to the Safety shop and get the right equipment for the job. The mask and gloves are special for the ingredients in the appoxy. resin Epoxy resin nearly got me put in hospital for 3 days
The epoxy resin still did get me but only slightly
On Hold Builds:-
Santa Maria
Member
Who is online
Users browsing this forum: Bing [Bot] and 6 guests
