Build log: San Juan by Artesania Latina 1/30(!)
User avatar
GaryM
Senoir Chief Petty Officer
Re: Build log: San Juan by Artesania Latina 1/30(!)
Postby GaryM » Mon Apr 25, 2016 4:21 pm
Looks like an interesting model to put together. I like a lot of the parts and the instructions that Artesania Latina uses. Their kits seem to make models for all ages and skill sets. This should make a great looking ship. The nice touches your adding will make it better.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
xenrunner
Seaman
Seaman
Postby xenrunner » Tue Apr 26, 2016 12:46 am
Gary hi,
Like I said, the main reason I chose this build is the challenges it presents ... leaves much room for imagination.
My biggest concern was the rigging of the cannons, but after watching a video on AL San Fransisco, I realized that San Juan is actually a watered-down version of San Fransisco kit. Now I know how I will proceed with the cannons. There certainly is not enough material (pulleys, etc.) so one have purchase them extra.
Also, there are almost no accsories for use on the deck (barrels, buckets, ...) and these have to be made from scrap wood.
I also have decided to create a battle-ready scene on the deck so I will make cannon ball brackets, gunpowder buckets, what have you. Let's see how it is going to come about ...
Finally, sorry about my ignorance of boat terminology, I guess I will learn proper terms in time.
User avatar
Donnie
Contact:
Postby Donnie » Tue Apr 26, 2016 9:04 am
It takes a long time (at least for me) to learn all the terms.....and I still can't remember all of them. Continue to enjoy your ship - that's what it's all about.
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
xenrunner
Seaman
Seaman
Postby xenrunner » Fri May 06, 2016 11:15 pm
... back to the city ...
The build commences ...
Planking and treenailing of the decks completed. This part basically ate time.
Decks are glued in place and some of the fittings installed ...
Some sanding needed to get the body in shape but not much.
Note for future builders: Cannon door spacing between the bulwarks and the main deck are not uniform! Cannons that will be under the quarter deck will have to be raised with a block of wood for better fitting & looks. Raising them does not sound very scale like but I seem to find no other solution to the problem.
User avatar
modelshipwright
Petty Officer Second Class
Contact:
Postby modelshipwright » Sat May 07, 2016 10:10 am
Nice clean work.
Bill
If it is worth doing, it is worth doing right.
Current build: Mantua Sergal bashed Sovereign of the Seas 1637
My Carving Book: Carving Ornamentation for Ship Models.
My website: http://www.carvingbook.weebly.com/
xenrunner
Seaman
Seaman
Postby xenrunner » Mon May 16, 2016 11:55 pm
Hi,
Bill, thanks for your comment. I like to take my time especially during the early stages of my builds; my innerself tells me the better the foundation, the better the final product :D
The build commences with the bullwarks. Again, nothing fancy but shaping of the nose can be somewhat tricky. I used some rope to achieve the correct shape and masking tape to keep it in form. After I get the part into shape I have moistened the parts and dried them with hair drier. Repeated this for 5 or 6 times until the fit became rigid enough.
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Postby eric61 » Thu Jun 02, 2016 5:18 am
Hi Cem, this may seem an unusual question, for you that is, but why have you put a deck fitting( belaying pin rack etc.) on the deck before the hull is planked?
Regards
Eric
Cook's Endeavour - current,
Sovereign of the Seas - current (deAgostini)
In queue: Marina II Fishing Boat by Artesania Latina
In queue: Mayflower by Model Shipways
"I was thinking then it all went blank!"
User avatar
Brian
Petty Officer Third Class
Postby Brian » Thu Sep 08, 2016 5:05 am
Hi Cem
your build is coming on very nicely, thought I would drop in and give you a tip, don't know if you have planked & fitted the metal portholes yet, but when I built this ship a couple of years ago I had a problem with the 6 portholes on the lower deck, they were all too low and the cannons wouldn't sit flat, ended up filing the top of the porthole and filing the bottom off the brass wheels to get them to sit right. if its not too late I suggest you try your portholes in and sit cannons in place.
My build can be seen on this site here
viewtopic.php?f=52&t=696
Brian
Who is online
Users browsing this forum: No registered users and 3 guests
