Build Log-Fair American MS2015
jbradford
Seaman
Seaman
Postby jbradford » Tue May 05, 2015 6:28 pm
Well, I am going to try and submit a build log for the Model Shipways Fair American.
The kit does not appear to be too difficult to follow and I will be using Bob Hunt's practicum. He has a couple of modifications that I am going to try as well.
After cutting the keel, stem, stern and bulkheads free, the did not require too much modification to fit. My first attempt at cutting in the rabbit was not as bad as I thought it would be. I glued the bulkheads, made the modifications to the starboard side to simulate a POF model and opened up the aft bulkheads in preparation for the Great Cabin. I then glued the stem, keel and stern pieces to the model and cleaned up and faired the model.
I look forward to any constructive criticism that you may have.
Jeff
FA closed box.jpg (271.34 KiB) Viewed 1422 times
FA open box.jpg (284.8 KiB) Viewed 1422 times
FA Plans.jpg (280.89 KiB) Viewed 1422 times
FA cutting out bulkheads.jpg (287.47 KiB) Viewed 1422 times
FA cutting out keel.jpg (256.89 KiB) Viewed 1422 times
jbradford
Seaman
Seaman
Re: Build Log-Fair American MS2015
Postby jbradford » Tue May 05, 2015 6:34 pm
Additional pictures during first week of the build.
FA Keel marked.jpg (206.3 KiB) Viewed 1421 times
FA bulkhead testfit.jpg (230.08 KiB) Viewed 1421 times
FA Starboard bulkhead mod.jpg (211.88 KiB) Viewed 1421 times
FA Stern keel mod.jpg (183.92 KiB) Viewed 1421 times
FA Starboard bulkheads.jpg (236.91 KiB) Viewed 1421 times
jbradford
Seaman
Seaman
Postby jbradford » Tue May 05, 2015 6:36 pm
More pictures of the first week build log.
FA Transom area.jpg (277.43 KiB) Viewed 1421 times
FA Stem and keel.jpg (299.46 KiB) Viewed 1421 times
FA keel and stern.jpg (275.21 KiB) Viewed 1421 times
DaveC
Petty Officer Second Class
Postby DaveC » Wed May 06, 2015 7:12 am
Jeff
Looks like you are off to a rousing start here.
I have been looking at this model as a possibility of my next build, as well as a couple of other ships.
I will be following along on your build here, with great interest.
Dave
Seattle
Sometimes it's necessary to go a long distance out of the way in order to come back a short distance correctly.
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Wed May 06, 2015 11:36 am
Nice start. The wood looks nice and strong. They seem to do a good job making their kits.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
jbradford
Seaman
Seaman
Postby jbradford » Sat May 09, 2015 11:18 am
I have attached the first 5 planks on each side and will post pictures in a bit. But, I have another question I hope you all may be able to answer. The practicum says to install the 6th plank, called the Black Strake plank and that there are only 2 in the kit, so one on each side. See the pictures attached as the practicum says to notice that it is wider than the other planks. How is 5/32 wider than 3/16?
In the last picture, the plank does look wider. Did I select the wrong strip from the kit?
Jeff
First 5 planks.jpg (43.3 KiB) Viewed 1324 times
6th plank.jpg (68.92 KiB) Viewed 1324 times
Wale planks.jpg (242.18 KiB) Viewed 1324 times
User avatar
GaryM
Postby GaryM » Sat May 09, 2015 6:00 pm
When I look at the picture, it seems the ends are probably 5/32" while the middle is wider. Maybe they tapered this one down in the front for you so that it would fit right.
Happy modeling,
Gary Maple
jbradford
Seaman
Seaman
Postby jbradford » Sat May 09, 2015 8:13 pm
According to Bob Hunt's practicum, no tapering is done on the hull planking until below the wales.
2.1 Planking the Hull The hull of Fair American is not too difficult to plank even though I am only going to be showing you a single layer of planking. This single layer is done in basswood, a soft wood used quite often in model shipbuilding that sands and bends fairly easily.
The process of planking the outer hull will be broken down into to primary steps. Planking the upper area which consist of planks without taper in them that go from the top of the hull to the bottom of the wales.
Jeff
User avatar
Donnie
Contact:
Postby Donnie » Sun May 10, 2015 7:32 pm
Jeff,
This is a mystery to me as well. I read your post and still can not figure out for you what the deal is with the instructions. It has to be a misprint somewhere. I wonder if they gave you also the wrong "2" pieces as well as an error in the instructions.
I know that you checked your parts list, but I could not resist to go back and look at just your wood only to see whats up with that. I have heard of this kit, but have not built it. I hope you can sort it out. I agree that the measurements do not seem to all add up like it should and also given the 2 planks that should be wider. I am not an expert, but usually wales (as it almost seems here) are a little considerably wider.
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
User avatar
Donnie
Contact:
Postby Donnie » Sun May 10, 2015 7:55 pm
I went to Model Expo website and much to my amazement, they had a parts list and you are correct. This is listed as such
WP3622- 24 1/16" x 3/16” x 24” 36 Hull planking, cap rail, fancy cap rail
WP3655- 24 3/32" x 5/32” x 24” 4 Main wales
WP3669- 24 1/16" x 5/32” x 24” 2 Use for Black strake
I also downloaded the instruction manual. The manual on my pdf reader would not allow me to copy and paste a paragraph, but they said to refer to Sheet 6 of the plans to take your measurements from (basically) of what to do. I am sure that you are very aware of all this. I am just confirming what you already are aware of. ...just trying to be of some help here. BUT, now I figured out how to get some of the text here.
Donnie
No Guts, No Glory !
Who is online
Users browsing this forum: No registered users and 1 guest
