King of the Mississippi
Moderator: zoly99sask
User avatar
Brian
Petty Officer Third Class
Postby Brian » Wed Oct 08, 2014 3:57 am
It seems only a few short weeks since I finished the San Juan and already have my next build on the go, which as you can see by the subject title is Artesania Latina's "King of the Mississippi".
Upon opening the box I was yet again impressed by the quality and packaging of the kit, with several layers of shrink wrap & selotape to protect during transportation.
Although tempted to start breaking out parts and gluing them together, I spent a couple of hours that evening unpacking and studying the instructions, and got going on it the next morning.
Showing contents of box (wrapping removed)
I do find the laser cut sheets to be f very high quality
2 containers with all the thread & metal parts in.
After first dry fitting these parts together, went ahead with gluing the frames to the false keel & bottom board.
I did fully intend to make a jig for this part like I have seen other do on this site, but such was the construction everything going into slots no jig was required, just put some weight on it to keep it flat whilst the glue dried, took the opportunity here to jump ahead a couple of stages and glue the 2 extension pieces to the 1st deck and prepare it for planking.
This picture shows the 2 bulkheads fitted (glued & pinned) and sanded ready to take the 1st deck, which has to be planked first.
Have to do a little research first as on this build I want to have a go at caulking & maybe treenails.
Not sure yet though if a paddle steamer warrants treenails.
I am sure other on this site will advise me on this matter :)
User avatar
catopower
Petty Officer First Class
Re: King of the Mississippi
Postby catopower » Wed Oct 08, 2014 11:12 pm
Hi Brian,
Congratulations on the new start! Wow, you showed great restraint in waiting until morning to start the build. I'm very impressed…
Looks like it's going to be a fun and interesting build!
Clare
User avatar
Brian
Postby Brian » Thu Oct 09, 2014 2:48 am
Hi catopower,
Thanks for your comments, yes it is going to be an interesting build and my biggest to date (Length=660mm x Height=192mm x Beam 130mm)
This is my fourth build, the other three being sailing ships so will make a change not to have any sails or rigging to do, I don't really enjoy that part, I was a carpenter not a seamstress :)
I do have to show some restraint, being retired now I would spend all day every day working on it until it was finished, then I would get bored again and be looking for another one to do.
My next job on the build should of been to plank the hull, but jumped ahead one stage to plank the 1st deck as I was keen to have my first go at planking with short planks and doing some simulated caulking. I didn't like the look of the 2 plank method shown in the instructions so went for a 3 plank method (see photo) as for the caulking after much research on the subject decided to go for the lead pencil on the edges look as I didn't want it to look too harsh, started by clamping a few together and rubbing all 4 edges with the pencil but also ran the pencil down the edge of each completed run after gluing in place, I am quite pleased with my first attempt at this and I understand that when varnished the caulking lines will stand out more, but first I am going to do some treenails on a test piece to see how it looks.
Edges of plank rubbed with lead pencil before fitting.
First deck planked, treenails to do, have to do some research first on what size holes and how to fill them etc.
edmay
Postby edmay » Thu Oct 09, 2014 12:49 pm
Hello Brian, real nice job of the decking,Edwin
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Thu Oct 09, 2014 1:59 pm
It is looking really good. Paddle-wheelers go together really fast. I have a article here on tree nails that will tell you the size to use based on the scale of your model. A four step pattern is usual so changing from the two step pattern was a good decision. In Donnie Dressel's book, he show the pattern to be used for tree nails based upon the width of the planks.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
Brian
Postby Brian » Mon Oct 13, 2014 12:52 pm
Thanks for the comments edmay, GaryM,
Not to sure about it going together real quick though, I am thinking it is going to take a while especially as I want to put more detail in than I did with the San Jaun (last build)
Didn't get to look at your article on tree nails Gary just went ahead and predrilled a 0.5mm hole and glued in the toothpicks, I can see why they are called tree nails now.
Time consuming & fiddly job but worth it in the end
!st deck completed except for more varnish to go on.
The hull took a bit of planking, some very tight corners to negotiate.
Hit a minor problem when I came to fit the first of the cabins (boiler room) put together & glued prior to fitting, the locating notch was almost a full hole out.
This was easily resolve doubling up the thickness of the wall, making sure first his didn't effect anything later.
Jumped ahead a couple of stages again whilst waiting for glue to dry and have been putting the herringbone pattern to the 2nd deck, now it is not like me to show off my faulty workmanship but looking at this photo I thought something looks a little off it was then I noticed just above the 16cm mark I had put 2 planks together without the step.
If I hadn't photographed this I may have missed it.
The mistake has now been corrected (glad it wasn't in the middle of the deck)
User avatar
GaryM
Postby GaryM » Mon Oct 13, 2014 4:25 pm
Nice job on the pattern.
Happy modeling,
Gary Maple
User avatar
Brian
Postby Brian » Mon Oct 20, 2014 8:48 am
Thought it was time for an update on my progress.
All 1st deck buildings now complete and glued into place and 2nd deck fitted.
User avatar
Brian
Postby Brian » Mon Oct 20, 2014 9:36 am
This next picture shows the 1st deck buildings, door frames & doors took some time to complete, very fiddly :|
2nd deck fitted, and showing the location of my next job, the spiral staircase.
This picture shows the supplied 1.5mm pre-cut hand rails, just too flimsy to bend into shape & if soaked first just fell apart.
Ended up removing the handrails and making up my own as shown.
The sides of the steps were first lined with short sections of basswood, the steps were then drilled to take toothpicks for the spindles and the handrails were made up with 2 layers Sapelli vaneer overlapping the joints to give extra strength.
Although not ideal, a little more work on this and a bit of paint and in my opinion the end result will be better than what was supplied.
User avatar
GaryM
Postby GaryM » Mon Oct 20, 2014 5:06 pm
Looks like you are making a fine model.
For items like the multi-layered items that must be bent, Amati make a heated plank bender. You can dip the wood in water for a couple of minutes only and then use the heat to bend and set the wood. The idea is not to wet the wood enough to let the glue start undoing but to cause a mild steam type of bending. Not sure if it would have worked on this model since the wood might have been to cheap. But might be of use on future work.
Happy modeling,
Gary Maple
Who is online
Users browsing this forum: Bing [Bot] and 3 guests
