Build Log: Eaglemoss HMB/HMS Endeavour 1:48 Scale
Moderators: Aussie048, zoly99sask
Post Reply
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Sun Aug 03, 2014 10:51 pm
Stay tuned to this channel, coming soon
Cook's Endeavour - current,
Sovereign of the Seas - current (deAgostini)
In queue: Marina II Fishing Boat by Artesania Latina
In queue: Mayflower by Model Shipways
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Sun Aug 03, 2014 11:59 pm
PLEASE NOTE, THIS INFORMATION WAS COPIED FROM WIKIPEDIA AND EDITED SLIGHTLY, IT IS NOT MY OWN RESEARCH!
Endeavour was originally the merchant collier Earl of Pembroke, launched in June 1764 from the coal and whaling port of Whitby in North Yorkshire(not too far from where I was born). She was ship-rigged and sturdily built with a broad, flat bow, a square stern and a long box-like body with a deep hold.
The flat-bottomed design made her well-suited to sailing in shallow waters and allowed her to be beached for loading and unloading of cargo and for basic repairs without requiring a dry dock. Her hull, internal floors and futtocks were built from traditional white oak, her keel and stern post from elm and her masts from pine and fir. Plans of the ship also show a double keelson to lock the keel, floors and frames in place.
Some doubt exists about the height of her masts, as surviving diagrams of Endeavour depict the body of the vessel only, and not the mast plan. While her main and foremasts are accepted to be a standard 129 and 110 feet (39 and 34 m) respectively, an annotation on one surviving ship plan records the mizzen as "16 yards 29 inches" (15.4 m). If correct, this would produce an oddly truncated mast a full 9 feet (2.7 m) shorter than the standards of the day. Modern research suggests the annotation may be a transcription error and should read "19 yards 29 inches" (24.5 m), which would more closely conform with both the naval standards and the lengths of the other masts. The replica is built to this shorter measurement, as is the model in the National Maritime Museum in Greenwich.
On 16 February 1768, the Royal Society petitioned King George III to finance a scientific expedition to the Pacific to study and observe the 1769 transit of Venus across the sun. Royal approval was granted for the expedition, and the Admiralty elected to combine the scientific voyage with a confidential mission to search the south Pacific for signs of the postulated continent Terra Australis Incognita (or "unknown southern land").
http://en.wikipedia.org/wiki/HMS_Endeavour
For the lower decking I followed the plans and laboriously cut those annoying short planks but for the upper decks I laid the full length plank down and marked the joins with a stylus and then a soft pencil and used a 'fineliner' pen to mark the 'nails'. Heaps quicker neater too.
Main Deck 1.JPG (108.08 KiB) Viewed 5360 times
User avatar
Donnie
Master Chief Petty Officer
Contact:
Re: Build Log: Eaglemoss HMB/HMS Endeavour 1:48 Scale
Post by Donnie » Mon Aug 04, 2014 9:14 am
Eric,
nice start on your build log. I am most sure that others will definitely tune in, including myself !
Donnie
Current Build: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
"War Ships are safe at harbor, but that is not what they were made for"
popeye
Contact:
Post by popeye » Mon Aug 04, 2014 9:24 am
agreed..........nice start on your build. I see your not planking the bow section with the first planking........are you saving it for the second planking? this would make sense, since you've used the fillers for the bow. why waste the planking on an area that has already been shaped.
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Mon Aug 04, 2014 10:22 pm
Thanks Donnie & Popeye.
To answer your question Popeye, the 'kit' comes with the ply pieces (about 1/8" thick) and the bow bow is built up, however, the pieces are not full pieces in other words they do not butt up against the keel piece, so when I glued them using a CA glue they shifted a bit consequently I will have to do a bit more sanding. The rudder end,duh!mind gone blank, transom I think, will post a picture soon, still has to be sanded back. That will give you an idea of the thickness. The finishing planks do go on to the bow former/s. The entire hull when finished will have a filler put on to it, tossing up between (what you call drywall)filler and car body filler, much harder but smoother.
We'll see when I get there. The outer planks @0.06mm thick are a wood called SAPELLI look a lot like mahogany, beautiful when varnished with clear. I have a stain varnish called 'New Golden Oak' which looks great on the 'white' timber and also give a deep luster to the sapelli.
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Tue Aug 05, 2014 4:49 am
The following shows fitting workable hinges onto the foredeck hatch. It took me about an hour to get it done! And there are two more hatches I want to do!!! something to do with lollypops and flogging.
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Tue Aug 05, 2014 5:00 am
Some deck fittings I have put off for ages because they were too finnicky.
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Tue Aug 05, 2014 5:10 pm
Regarding the forward hatch, the hinge pins when cut are 4mm long and after opening and closing the hatch a few times one of the pins fell out. I will post a picture of the finished hatch later today.
Eric
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Wed Aug 06, 2014 1:55 am
Ok, here are the pictures, I very carefully crimped the back part of the hinges to tighten them up a bit and the hatch now stays open at whatever angle. I still have to put a pull ring on the other end of hatch. I won't be able to do any thing for the next two days as I will be transporting dialysis clients to and from clinic and their homes.
BY THE WAY, does any one have any plans/drawings web links on where I can get a 1:48 scale slipway as used prior to launch, thanks in advance.
Eric
popeye
Contact:
Post by popeye » Thu Aug 07, 2014 10:50 am
nice touch on the hold covers......I toyed with opening doors on a 1:33 scale fishing boat {Mary Ann - Billing's}. I haven't done much else with it though, considering how often I open and close the doors on it, which is hardly ever :)
it does add detail to the hinges though......and that's a good thing :) I have a few 1:30 scale build in my horizon.......I might do more with it then.
for wood, I use mostly basswood and Obechi. Billing kits are pretty big on these two, Obechi is an African wood {so I'm told} very rough, and not smooth by any sense of the word. I try to pre sand them before I use them, to cut down on the finish sanding. it doesn't bend as well either......best to bend them in a group, so to get a better shape. another woos that is a Billing's staple, is Annegre. this is a lighter color of mahogany.......and works really well for deck planking and second hull planking. the best wood used is wood that doesn't require a lot of sanding......but that's a pipe dream ;)
you've done a nice looking deck......have you fitted it out at all? looking forward in seeing more of your progress.
Post Reply
