Royal Louis 1780. First Rate French Vessel.Mamoli 1/90 scale
User avatar
popeye
Master Chief Petty Officer
Contact:
Re: Royal Louis 1780. First Rate French Vessel.Mamoli 1/90 s
Postby popeye » Tue May 13, 2014 8:22 am
tough call........they would have to be cut at the lower deck, And use the upper deck to align them when they are cemented in the correct place.
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
User avatar
CharlesEdward
Petty Officer Second Class
Postby CharlesEdward » Fri Jun 20, 2014 9:12 pm
Nice kit, I have this one also, but haven't started it yet as I have six kits on the bench so to speak. I will keep tabs of your progress and take notes. On my Euromodel Royal William, I HAD to use the lower gun decks to in fact help align all of the frames and in fact, I had to cut the precut deck pieces in half in order to even get them to fit into the very tight frames of that model. They are not quite perfect, but hopefully, the errors will be quite hidden when it is completed.
My Royal Louis kit arrived with the three main false keel pieces all warped to one extent or another. I requested a replacement bow part and THAT even came warped, even worse than the original. I have had all three false keel pieces seriousley clamped between two pieces of wood for over two years now and finally unclamped them and put them back into the box. They did look a little better, but they could warp again, in that case, I will probably cut three new pieces, or one big piece myself, once I start building it.
JohnK aka Charles Edward
Current builds: Montanes, Albatross; Sao Miguel; Albatross; Wappen von Hamberg; Royal William.
Completed kits: Santa Maria; USS Dallas, Scottish Maid; Half Moon; Golden Hind, Yacht Mary; HMS Sharke.
Ulises
Seaman
Seaman
Postby Ulises » Thu Jun 26, 2014 2:31 pm
Update Jun 26 2014.
Hello all. A small update of my Royal Louis build.
Thanks for visiting.
Ulises
Fitting of rear cannon frames and planking
Royal Louis (1063).jpg (65.14 KiB) Viewed 1548 times
Royal Louis (1064).jpg (54.34 KiB) Viewed 1548 times
This planking is not finished yet.
Royal Louis (1066).jpg (61.68 KiB) Viewed 1548 times
Royal Louis (1067).jpg (58.46 KiB) Viewed 1548 times
Some of the slots for the metal cannon frames mounting lugs had to be redone for a proper alignment
Royal Louis (1072).jpg (55.72 KiB) Viewed 1548 times
Royal Louis (1075).jpg (54.26 KiB) Viewed 1548 times
Dry fitting of the frames checking for proper height, so the cannon and carriages assembly will properly fit through the hole. A lot of trimming and filling had to be done here. This is a job that has consumed a lot of my time because I know this step is critical and want to do it to the best of my abilities.
Royal Louis (1076).jpg (55 KiB) Viewed 1548 times
Royal Louis (1079).jpg (61.22 KiB) Viewed 1548 times
First time ever I use balsa to fill the empty spaces at the bow and rear areas, for a better shaping of the hull.I know its not the cleanest of the jobs, but I think it will serve it's purpose. A few holes will have to be carved here to accommodate cannon frames.
Royal Louis (1071).jpg (55.26 KiB) Viewed 1548 times
Royal Louis (1074).jpg (58.35 KiB) Viewed 1548 times
This is a "test board" I made to try different finishes and wood treatments to help me decide how I am going to finish my ship.
Royal Louis (1065).jpg (59.28 KiB) Viewed 1548 times
There aren't but two options: do it fast, or do it right!
User avatar
popeye
Contact:
Postby popeye » Fri Jun 27, 2014 9:30 am
looking good.......once planked, you'll never see it again! let the beauty shine!
good idea with the color chart......great for blending shades ;)
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
Who is online
Users browsing this forum: No registered users and 5 guests
