Royal Louis 1780. First Rate French Vessel.Mamoli 1/90 scale
Moderator: zoly99sask
Ulises
Seaman
Seaman
Postby Ulises » Sun Apr 13, 2014 1:59 pm
Hello all.
I'm starting my build log of my Royal Louis, which I started on April 12 2014.
Box on my table. As you can see, I have very limited space to build. Box fills my entire table almost. LOL
Royal Louis (1).jpg (73.19 KiB) Viewed 5001 times
Box content
Royal Louis (2).jpg (66.79 KiB) Viewed 5001 times
Plans and instructions (if they can be called that :P) folder.
Royal Louis (3).jpg (65.37 KiB) Viewed 5001 times
Frames still packed
Royal Louis (5).jpg (75.5 KiB) Viewed 5001 times
Rest of wooden material
Royal Louis (6).jpg (66.99 KiB) Viewed 5001 times
Assorted bags with assorted fittings. I have to say I am a little disappointed with so many metal parts. I will try to replace some, but I am no scratch builder.
Royal Louis (7).jpg (90.64 KiB) Viewed 5001 times
You will never ever are going to see my work place (it's actually a blanket closet) this clean and neat again. And yes...this is all the room I have to build my ships.
Royal Louis (11).jpg (86.77 KiB) Viewed 5001 times
OMG! Look at the size of this skeleton. It almost fills my table! And no bowsprit yet! Where am I going to do the actual work? :P
Royal Louis (14).jpg (72.99 KiB) Viewed 5001 times
There aren't but two options: do it fast, or do it right!
User avatar
GaryM
Senoir Chief Petty Officer
Re: Royal Louis 1780. First Rate French Vessel. Corel 1/90 s
Postby GaryM » Sun Apr 13, 2014 5:01 pm
Good luck. Hope you enjoy the build. I agree that the price of the kit is a little high considering the quality and pot metal simplifications. Mine looks like an older kit than yours so hopefully they made some improvements.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
otrax01
Petty Officer First Class
Postby otrax01 » Sun Apr 13, 2014 7:16 pm
I think the wall to the right needs to be removed, and clear out whatever room is on the otherside. If your working on your ship, you wont be needing that room over there :text-lol: , :text-imsorry:
Kent
Remember, When your out in the shop, Ship Happens!
___________________________
Finished Builds: Le Mirage by Corel
Current Build: HMS Victory by Mamoli
User avatar
popeye
Master Chief Petty Officer
Contact:
Postby popeye » Sun Apr 13, 2014 7:18 pm
very nice start ! one of these days......I'll get into one of these :D :D
Ulises
Seaman
Seaman
Re: Royal Louis 1780. First Rate French Vessel.Mamoli 1/90 s
Postby Ulises » Mon Apr 14, 2014 6:31 am
(Corrected the title of the initial post where it said this kit was by Corel. Corel was my recently finished Vasa, which you can see in the Completed Builds Forum. This is a Mamoli)
viewtopic.php?f=3&t=670
GaryM. I felt sad when you decided to quit building the RL. I was hoping that you made the mistakes and let me know about them :lol: (J/K) I have always wanted this kit, but just couldn't afford it. Then in May 2010 Model Expo offered it at 450 dlls. and I just couldn't pass the opportunity.
Kent: I don't think the person using that room will be to happy. :)
Popeye, go for it.
A strip of wood over the (still unglued) frames showed they were misaligned.
Royal Louis (13).jpg (54.01 KiB) Viewed 4984 times
Arrows show how and which frames had to be modified
Royal Louis (14).jpg (52.36 KiB) Viewed 4984 times
When needing to rise, a small bit of wood was glued to the slot
Royal Louis (15).jpg (42.87 KiB) Viewed 4984 times
User avatar
Donnie
Contact:
Postby Donnie » Mon Apr 14, 2014 11:12 am
Very Nice Box --- Huge ! I will be watching this one for sure.
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
User avatar
popeye
Contact:
Postby popeye » Tue Apr 15, 2014 8:36 am
did the unevenness interrupt the slots for the gun port? in the pictures, it didn't look like it did. perhaps shimming the tops under the deck might be an option.
Ulises
Seaman
Seaman
Postby Ulises » Tue Apr 15, 2014 6:50 pm
Update April 15.
Glued all the frames, the 2 square bars that go all the length of them and a small piece that seems to be some sort of a holding place for the main mast.
Popeye: good point. Didn't think about that, but apparently there are just a few and minor misalignments
So far, so good!
Thanks for watching.
Making sure frame 1 is 90o to the keel.
Royal Louis (16).jpg (58.06 KiB) Viewed 4944 times
Double check.
Royal Louis (17).jpg (58.93 KiB) Viewed 4944 times
A few more frames
Royal Louis (18).jpg (57.98 KiB) Viewed 4944 times
Royal Louis (19).jpg (59.11 KiB) Viewed 4944 times
Making sure at every step along the way, that everything is as it should, and still.... mistakes happen. :P
Royal Louis (20).jpg (66.07 KiB) Viewed 4944 times
All frames and 2 bars that go all along the hull glued in place.Also a small piece that seems to be a holding place for the main mast. Views from different angles
Royal Louis (21).jpg (75.69 KiB) Viewed 4944 times
Royal Louis (22).jpg (74.95 KiB) Viewed 4944 times
Royal Louis (23).jpg (70.35 KiB) Viewed 4944 times
Royal Louis (24).jpg (53.17 KiB) Viewed 4944 times
Royal Louis (25).jpg (60.4 KiB) Viewed 4944 times
User avatar
GaryM
Postby GaryM » Tue Apr 15, 2014 7:47 pm
I found that you have to put all the decks in and then us a penetrating glue to lock in the frames. The decks need to be right is the most important thing. Mine was a very tight fit that way. You do not have to glue the deck in until you are ready, but they should be in when you glue the frames.
Happy modeling,
Gary Maple
Ulises
Seaman
Seaman
Postby Ulises » Tue Apr 15, 2014 9:38 pm
GaryM wrote:I found that you have to put all the decks in and then us a penetrating glue to lock in the frames. The decks need to be right is the most important thing. Mine was a very tight fit that way. You do not have to glue the deck in until you are ready, but they should be in when you glue the frames.
Too late! Frames are already glued. I tried to fit the decks and saw that I'm going to have to do a lot of sanding for them to fit. Hopefully the planking will cover that. :sad:
Who is online
Users browsing this forum: No registered users and 3 guests
