Billing's Half Moon - 1:40 scale - by Popeye
User avatar
popeye
Master Chief Petty Officer
Contact:
Postby popeye » Tue Mar 04, 2014 7:55 am
it was a sad day, when I heard that the Billing Boats store in Wisconsin was closing down. Tom and Susan are such good folk, and I enjoyed working with them a lot! Tom let me know that there were some 'odds and ends' that he was sending to me......thought I could use it. I thanked him and let him know that if they ever started anything up in the future......I'd be more than happy to jump on the band wagon!
In the box he sent, was some odd ball woods.....some even bagged, slated for kits, some paints and tools.....other assorted parts and stuff. but, in the bottom of the box, was this kit....the Half Moon. it is an incomplete kit....some parts are missing......an entire sheet to be exact. but, the hull parts are all there, so that is a plus. use it as I see fit, was the words he used, probably feeling that the model was unbuildable, due to the missing parts. as a modeler however........I see things in a much different light...no model is unbuildable, no matter how degraded the kit is. I proved it with the Nordkap.....even after 20+ years in an attic, it turned out to be a fine build.
I had other builds in the que.....but it didn't stop me from tinkering in the box, fitting the frame and keel. it was doable.........and so I will :D and so....in May of 2013, I began this build.....knowing that I would be bashing and scratch building along the way
the kit box....generic packaging
some of the wood...appears to be all there....even found an extra bag of dowels
the bag of fittings....I will do something with the life boat...that's down the road though
pretty much all the wood parts there are...the hull parts aren't here, they are on my table.....dry fitted together
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Re: Billing's Half Moon - 1:40 scale - by Popeye
Postby popeye » Tue Mar 04, 2014 8:01 am
you can see that the hull parts have been removed.......and also the package that I store all of the cast offs and pop outs. I save all that stuff.....you never know where your going to need them. I don't toss the parts panels either.....there are times where some 'like wood' is needed. I find that working with any aspect of the build, and you want to bash it in some degree, it good to have wood of the same texture around to do it. .....just doesn't look right when your working with plywood, and you finish the bash work with basswood or something. it's good to make it look like it was part of the kit, which is what I try to do.
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Tue Mar 04, 2014 8:27 am
5-8-2013
there was part of the build slip included in the kit. I put it together, so the parts would not get lost. when I get around to it, I will buy a suitable board and cement this to it.......make another slip out of it :D the hull frame is assembled at this point.
this is a good find.......I can have a second build slip
the keel parts...assembled and allowed to dry.
I have the instructions....but they are vague at best
the frame progress
I added some strip stock along the keel to help support the ribs
progress toward the stern
stopped here to install the two support strips in place
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Tue Mar 04, 2014 8:38 am
the two support strips were added through the holes you see in the ribs. I wasn't going to add them in......I feel that in some kits, they are a waste. the deck platforms give them all the support they need. where I wasn't sure how soon the frame would be planked.......I added them in.
putting in the upper stringers..I should have ran them all the way to the stern
the frame is assembled
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Tue Mar 04, 2014 8:54 am
5-13-2013
perils.....of perils.......the fears of the build! I had removed the knock-out for the bow, and the sanding and handling caused that thin bridge on the bow stem to break! I glued it back in place, and put the knock-out back in for now.....I should have known better! the deck platforms were cemented in pace at this point.....I had to scratch produce the upper stern platform, the main deck, and the bow platform.
broke the thin bridge at the top. it was fixed and the knock-out was put back in place
these two were in the kit
start of the main deck
main deck in place
so far.......
making the bow platform
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Tue Mar 04, 2014 8:57 am
5-14-2013
the upper deck platform......more scratch work
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Tue Mar 04, 2014 9:08 am
5-16-2013
once all the deck parts were made, they were cemented in place.
the main deck platform
the bow rabbits
the lower aft deck.....the upper aft deck is already in place
creating a seat for the bow platform
bow platform in place
it might have been a smart thing to allow the supports to protrude under the bow platform....hindsight, is it a good thing?
the framework for the transom planking
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Tue Mar 04, 2014 9:11 am
H ave to chuckle a bit.......I was still working on the AmericA, when I started this.
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Tue Mar 04, 2014 9:17 am
5-21-2013
the transom was fun to do.......made from three different sizes of wood
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Tue Mar 04, 2014 9:21 am
my builds are all around me......the Boulogne Etaples is off to my left, the Gothenborg is under wraps, and the AmericA is to my right. the Wharf is a very busy place :D ;-)
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
Who is online
Users browsing this forum: Canoe21 and 2 guests
