Bluenose II (Constructo, 1:135) by Klarre
User avatar
klarre
Seaman
Seaman
Postby klarre » Tue Jan 07, 2014 2:22 pm
Hello everyone,
Just received my first wood model ever - The Bluenose II. The Bluenose was a Canadian fishing and racing schooner. In 1946 she got stuck and abandoned on a reef outside of Haiti. The wreck has not been found but a Bluenose II was built in 1963 using the original plans.
This kit from Constructo is supposed to be pretty easy to build, even though it doesn't look that easy to me. ;)
I'm very excited to get started, and expect some pictures the forthcoming days. :)
/Klarre
User avatar
catopower
Petty Officer First Class
Re: Bluenose II (Constructo, 1:135) by Klarre
Postby catopower » Tue Jan 07, 2014 2:55 pm
Congratulations on getting your first ship model kit, Klarre!
Looks like it's going to be a fun build.
What do you think about the tools that were included? I know the set you bought will far exceed what came in the kit, but I'm just curious what came with it and what you think of them.
Clare
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Tue Jan 07, 2014 3:13 pm
Looks like you may have a preformed hull but it gets planked over. Should be an interesting kit to put together and a good choice for a first kit.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
klarre
Seaman
Seaman
Postby klarre » Tue Jan 07, 2014 3:20 pm
Thanks Clare!
The nipper and pliers feels like a good complement to my kit and will be useful. I'm more skeptical to the sanding tools. Both are very jagged and I'm not sure where I'm supposed to use these, because if I use them on the hull I need to be extremely careful. On the other hand I'm a beginner so maybe it makes sense when I start working with them. But I will replace the sanding paper with a more soft one to start with.
User avatar
Donnie
Contact:
Postby Donnie » Tue Jan 07, 2014 4:46 pm
Congratulations Klarre on your new schooner ! The box contents really look very well made. I am sure that your Bluenose will turn out well.
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
User avatar
klarre
Seaman
Seaman
Postby klarre » Sun Jan 12, 2014 7:42 pm
Spent the Saturday by gathering all missing tools and glues, and tonight I got some time working on my shooner.
I had a piece that was pretty bent so I followed Donnie's tips to straighten it up before glueing it on the preshaped hull that this kit comes with. It's the piece that you can see in the image below which is currently drying as I write this update.
I've already done the sanding to line up the piece with the hull (you can see that the piece goes over the edge in the image which is what I have fixed now), so the next step is the planking which I will do tomorrow. I'm really looking forward to this since its such a nice detail. :)
As you can see I also bought a plastic box to separate and keep all small pieces safe. Unfortunately I found out that two deadeyes were missing when I counted the pieces. Should be a fairly common piece and not that hard to found as a spare piece in a model shop though.
User avatar
jct
Postby jct » Tue Jan 14, 2014 4:18 am
Your off to a great start Klarre, very nice set of tools, they should serve you well. Good job correcting the warped piece.
J :cool:
Current build -
In the queue -
Agilis, Steingraeber
HMB Endeavour, Corel
Harriot Lane, Model Shipways
Semi complete-
USS Niagara
Completed builds-
Half Moon, Corel
USN Picket Boat #1
User avatar
Donnie
Contact:
Postby Donnie » Thu Jan 16, 2014 5:19 pm
This will be very interesting to watch !
No Guts, No Glory !
User avatar
klarre
Seaman
Seaman
Postby klarre » Mon Jan 20, 2014 7:13 pm
Hi again,
Just wanted to share a short update. I haven't been able to work as much on the ship as I wished for, but I'm making small progress as soon as I got some spare time. :)
As you can see I'm still working with the hull. I've done some planking and today I glued the gunwale. Had to redo one of them since I managed to wet, bend and dry it in the wrong direction.
One of the most important thing I've learned so far is that gluing is kind of tricky. I've been using too much and got glue all over the ship and it doesn't look that nice. The deck planking isn't that nice either since there is glue between some planks and in some places there are no glue at all, making it look uneven. If I had thought about it earlier I would have made some cuts with a knife between the planks to make it better looking.
The plan today was also to add the back gunwale, but now the time is 1 AM and I'm pretty sleepy, so I will leave it here for today.
2014-01-21 01.02.47.jpg (101.33 KiB) Viewed 5225 times
probablynot
Petty Officer Second Class
Postby probablynot » Mon Jan 20, 2014 7:54 pm
My goodness, you're organised Klarre!
I love how you sorted out your preliminary toolkit before starting on the actual building work. Way to go!
I looked at the Bluenose kits when I was starting into this hobby. I would have bought one (instead of the AL Mare Nostrum kit I eventually chose) but I really wanted to try the planking instead of going for the solid hull. I actually think it's more skillful to get a properly-shaped solid hull than a decent-looking plank-on-bulkhead one, so all credit to you!
You seem to have made good progress so far with your Bluenose II. Keep up the good work, and keep us informed.
Who is online
Users browsing this forum: NMBROOK and 4 guests
