Half Moon by Corel
User avatar
jct
Petty Officer First Class
Half Moon by Corel
Postby jct » Sun Dec 22, 2013 7:53 am
This will be a new experience for me in two ways, 1st this is only my second build of a wooden ship, though I have built many plastic kits, and 2nd building with have a virtual audience looking over my shoulder!
The kit is Corel's Half Moon, which has received some attention here from others, I agree it is a very nice kit.
I'll include as many photos of progress as I can and try to clarify with commentary when appropriate. I've already committed a few mistakes and will have to deal with them later, my hope is that others just starting out can gain from my experience and enjoy the hobby as I do.
THX
J
This is the first pic I have of the build ( didn't decide to do a log until it was this far along) as you can see there will be a lot of filling and shaping before the second plank layer can be applied. I glued up the frames before I realized there were issues to correct...build and learn!
1-deck planking.jpg (112.74 KiB) Viewed 5558 times
This pic show a little jig for getting all the deck planks a consistent size, just a true wood block with a few brads, 4 to keep the plank stable and another to set the size. works well
2-plank sizing jig.jpg (90.58 KiB) Viewed 5558 times
Using an old syringe to apply glue, makes for a much neater job
3-glue application.jpg (75.21 KiB) Viewed 5558 times
Deck planking about 80% complete...took a break to add a few more starks.
4-deck planking.jpg (129.94 KiB) Viewed 5558 times
fragle123
Petty Officer Second Class
Re: Half Moon by Corel
Postby fragle123 » Sun Dec 22, 2013 10:49 am
Looking good and like the syringe idea, if it wasn't for the mistakes we all made along the way then we would not progress and improve our skills i should know as iv'e made lots along the way.
cheer steve
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Sun Dec 22, 2013 3:29 pm
Should make a nice build. I keep a notebook handy and list my way of solving a mistake or list what to watch for on the next build so as to avoid making the same mistake. I go back after the information gets cold and read the notes to see if I need to write them over so that they make sense.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
jct
Postby jct » Sun Dec 22, 2013 7:34 pm
Good tip Gary, on I'll utilize
THX
J
Current build -
In the queue -
Agilis, Steingraeber
HMB Endeavour, Corel
Harriot Lane, Model Shipways
Semi complete-
USS Niagara
Completed builds-
Half Moon, Corel
USN Picket Boat #1
fragle123
Postby fragle123 » Mon Dec 23, 2013 6:26 am
Never thought of that GaryM good idea, have to remember that for the future
cheers steve
User avatar
jct
Postby jct » Tue Dec 24, 2013 2:51 pm
more build done today, photos and comments follow
As I stated earlier I glued up the bulkheads prior to checking them, I had to shim the sides to prevent having a huge divot in the side of the hull
5-resizing timber heads.jpg (83.65 KiB) Viewed 5520 times
following the kit instruction lead to this one, I have all the deck plywood glued down...so planking through allowable spaces. Glad I caught it before I planked all the way up!
7-decking through the hole.jpg (69.91 KiB) Viewed 5520 times
Just squaring up the stern ply sheets here
8-squaring the stern.jpg (68.75 KiB) Viewed 5520 times
More inside work, sanding the deck contour into the bottom wall board to mount inside the aft deck house
9-contouring wall boards to match the curve of the decks.jpg (52.59 KiB) Viewed 5520 times
10-wall boards mounted.jpg (44.44 KiB) Viewed 5520 times
Deck planking is complete more hull planking to do
11-planking cont..jpg (80.91 KiB) Viewed 5520 times
12-planked up past timber heads.jpg (97.69 KiB) Viewed 5520 times
Transferring the pattern traced off the plans to the side of the hull to be cut
13-transfering pattern.jpg (63.64 KiB) Viewed 5520 times
14-final markup.jpg (101.69 KiB) Viewed 5520 times
Excess cut away and some sanding complete...next up planking the bottom...but that's for another day
16-after some preliminary sanding.jpg (63.85 KiB) Viewed 5520 times
Current build -
In the queue -
Semi complete-
USS Niagara
Completed builds-
Half Moon, Corel
USN Picket Boat #1
User avatar
catopower
Postby catopower » Thu Dec 26, 2013 12:33 pm
Hi JCT, hope you had a nice Christmas!
Nice progress on your Half Moon model. What are you using to bend the planks?
I've seen a few Half Moon builds and it's a nice looking ship. You are planting the seed in the back of my head to try to build one myself one of these days.
By the way, that's a great ideal about the syringe. I've seen that done before, but your post and my current builds are really making me think about doing the same. That's would make some things a lot easier. And, less messier!
Clare
User avatar
jct
Postby jct » Thu Dec 26, 2013 4:19 pm
Hey Clare,
The syringe does make things neater, just be sure to clean it well at the end of each session the glue likes to set up fast.
For bending I've just been soaking in hot water and manually bending around a couple 1inch glass grinding bits from my glass grinder, once they dry I remove the clamps. The bend is a little to much for the bow so I've been re-wetting them and relaxing the bend prior to mounting. I've a pic in the camera I'll download next time I post.
THX
J
Current build -
In the queue -
Semi complete-
USS Niagara
Completed builds-
Half Moon, Corel
USN Picket Boat #1
User avatar
jct
Postby jct » Fri Dec 27, 2013 4:22 am
Here are the promised pics of bending the planks I mentioned in my last post.
J
17-bending plank.jpg (73.47 KiB) Viewed 5477 times
18-plank bent.jpg (86.29 KiB) Viewed 5477 times
little door for the forward cabin, still need some kind of pull, I'm thinking of using a simple brass ring?
19-little door.jpg (80.58 KiB) Viewed 5477 times
Current build -
In the queue -
Semi complete-
USS Niagara
Completed builds-
Half Moon, Corel
USN Picket Boat #1
User avatar
jct
Postby jct » Sun Dec 29, 2013 10:47 am
Build continued, started this session by carving away some of the thickness at the dead wood to allow the planks to sit more flush and to allow for the instillation of a separate stern post. After I proceed to soak and bend a plank that will eventually become the garboard plank. After drying the planks were trimmed and glued in place with a combination of CA and woos glues.
20-Bending the garboard.jpg (106.93 KiB) Viewed 5462 times
23-trimming the deadwood.jpg (47.51 KiB) Viewed 5462 times
25-stern post.jpg (87.66 KiB) Viewed 5462 times
26-gluing the garboard.jpg (104.7 KiB) Viewed 5462 times
Current build -
In the queue -
Semi complete-
USS Niagara
Completed builds-
Half Moon, Corel
USN Picket Boat #1
Who is online
Users browsing this forum: No registered users and 5 guests
