Atesania Latina kit HMS Supply
Moderator: zoly99sask
fragle123
Petty Officer Second Class
Postby fragle123 » Thu Nov 07, 2013 2:02 am
Hi all
This will be my first attempt at building a period ship and so the most daunting task ahead of me at the moment will be when i come to do the rigging and sails i think.
Ok more about the kit itself, it is from Artesania Latina and upon opening the box things look good it has a comprehensive set of instructions for the rigging and a basic set of instructions for the building side of things in multiple languages plus a small booklet with pictures of each step inside and full scale colour plans.
A lot of the fittings are cast metal which look like good quality but i may change some of these and reconstruct my own in wood, i will make my mind up about that at a later stage when i see how they look after being painted, if they don’t look right then i will redo them.
I do not take any interest in researching the history of a ship other than what historical data comes with it, I do this for the pure pleasure and satisfaction of building something and making it look as good as I can, and the only thing I know about this ship is that it was the first ship that left the UK carrying convicts for Australia in 1788.
HMS SUPPLY 010.JPG (143.22 KiB) Viewed 5076 times
HMS SUPPLY 011.JPG (148.57 KiB) Viewed 5076 times
HMS SUPPLY 012.JPG (142.69 KiB) Viewed 5076 times
HMS SUPPLY 013.JPG (152.62 KiB) Viewed 5076 times
HMS SUPPLY 015.JPG (153.91 KiB) Viewed 5076 times
HMS SUPPLY 016.JPG (157.47 KiB) Viewed 5076 times
User avatar
catopower
Petty Officer First Class
Re: Atesania Latina kit HMS Supply
Postby catopower » Thu Nov 07, 2013 1:54 pm
Hi Fragle123,
Glad to see you starting a build log on your HMS Supply. I'm working on a modified Artesania Latina Colonial Schooner kit, myself. If your kit is like mine, I think you'll enjoy the build. I think you picked a very good subject as it is well document and not just some fictional vessel, like the Colonial Schooner. And, being that it's a brig, you'll have a little less rigging to deal with than with a full-rigged ship.
I'm looking forward to watchin your model progress!
Clare
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Fri Nov 08, 2013 2:46 pm
This is a big commitment to take on as your first vessel. I am sure it will make a great ship. It is important thing to do is read the directions all the way through so that you get an idea of how it goes together. As you start a step, reread the instruction and make sure you can visualize how the will look together.
There are some really knowledgeable people here and if you have questions, ask and people will help.
Good luck and enjoy.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
Donnie
Contact:
Postby Donnie » Sat Nov 09, 2013 1:29 am
Hi Fragle,
It is great that you are starting a build log on this. Don't worry - I am not a history person either.
May I make a suggestion. The very first thing to do is to make you a "building board". The building board will be the docking place for your ship during its construction.
Actually, there are two building boards. The first one is made to hold the frame in place and square. Then later, another building board is made that will be somewhat permanent until the ship is mounted in some form or another.
The first image is the ship sitting in a cradle. The next is the building board holding the Bulkheads in place. Notice the spacers. All of this is made with MDF (Medium Density Fiberboard) - glued the spacers, etc in place using regular Tite Bond.
And speaking of glue - my humble opinion is to use the Titebond wood glue for your framing because you want to make adjustments and to maintain squareness as the Bulkheads dry.
I dry fitting most all the Bulkheads (the rib looking pieces) and after it all looked ok, then I did not remove the pieces. I let the Tite Bond glue basically run down the sides (joints) and let it soak in. This way you are not disturbing any alignments. Just make sure that you do not overlook any glue that might run on down and wind up gluing the frame to your building board.
However, let me say that others have come up with building boards that do not resemble what I have shown, but have actually come up with some rather more-better creative way than this.
When the frame is dry, turn the frame upside down on a very flat surface. Look at all four corners of the frame and see what parts are touching the flat surface. This will automatically verify if you have any twist in the frame.
Remember that a very small error in framing will result in larger problems later. They accumulate. A nice square frame will make planking your hull a lot better and be more symmetrical.
Everything has a tolerance and "give and take" when it comes to all of this. The main point is that everything is within reason. Just like with machinist - they do not use the word perfect. They use the word tolerances.
And after all, it is your model and your creativity. You are the one that will ultimately be the judge.
Enjoy !
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
fragle123
Postby fragle123 » Sat Nov 09, 2013 2:32 am
thank you for the advice and tips i will have to remember those for the next time as this build is well on its way to completion maybe just a few months work left to do.
I have been trying to upload some more photos but they're not showing up when i go to preview them or being added after i click the add file button im sure the problem lays with me but i will get it sorted im sure
cheers steve
fragle123
Postby fragle123 » Sat Nov 09, 2013 1:15 pm
got it sorted now
fragle123
Postby fragle123 » Sat Nov 09, 2013 1:24 pm
here are some more photos showing the early stages of the build
HMS SUPPLY 001.JPG (155.99 KiB) Viewed 5025 times
HMS SUPPLY 002.JPG (157.73 KiB) Viewed 5025 times
HMS SUPPLY 003.JPG (119.58 KiB) Viewed 5025 times
HMS SUPPLY 004.JPG (133.51 KiB) Viewed 5025 times
HMS SUPPLY 006.JPG (139.14 KiB) Viewed 5025 times
HMS SUPPLY 007.JPG (97.69 KiB) Viewed 5025 times
HMS SUPPLY 008.JPG (135.58 KiB) Viewed 5025 times
HMS SUPPLY 009.JPG (140.3 KiB) Viewed 5025 times
HMS SUPPLY 010.JPG (131.5 KiB) Viewed 5025 times
HMS SUPPLY 011.JPG (153.68 KiB) Viewed 5025 times
HMS SUPPLY 012.JPG (130.12 KiB) Viewed 5025 times
User avatar
GaryM
Postby GaryM » Sat Nov 09, 2013 3:52 pm
Looks like a good start on a nice kit. It seems like their fittings are nicely done and very clean.
Happy modeling,
Gary Maple
fragle123
Postby fragle123 » Sun Nov 10, 2013 5:32 am
Hi Gary
yes i was quite pleased with the way things went together i do believe this is meant as a starter kit and therefore alot of the deck fittings were cast metal and i did notice that the small photo booklet you get with the kit showed some of the fittings in wood but the same fittings in the kit are metal and i just did not like the look of some of them so made an attempt at scratch building my own.
cheers steve
fragle123
Postby fragle123 » Tue Nov 12, 2013 1:14 am
Here is the start of the hull planking sorry some of the images are blurred, had problems with this camera at the time and eventually bought a new one
Deck planking done i then gave it a couple of coats of Danish Oil
HMS SUPPLY 001.JPG (143.31 KiB) Viewed 4989 times
HMS SUPPLY 002.JPG (152.22 KiB) Viewed 4989 times
HMS SUPPLY 003.JPG (143.45 KiB) Viewed 4989 times
planked the aft end
HMS SUPPLY 004.JPG (116.63 KiB) Viewed 4989 times
first planked layed and gave the planks a good soaking and then used a soldering iron to bend them
HMS SUPPLY 005.JPG (133.16 KiB) Viewed 4989 times
HMS SUPPLY 006.JPG (150.23 KiB) Viewed 4989 times
HMS SUPPLY 007.JPG (124.01 KiB) Viewed 4989 times
HMS SUPPLY 008.JPG (127.09 KiB) Viewed 4989 times
HMS SUPPLY 009.JPG (125.86 KiB) Viewed 4989 times
HMS SUPPLY 010.JPG (131.98 KiB) Viewed 4989 times
HMS SUPPLY 011.JPG (124.61 KiB) Viewed 4989 times
HMS SUPPLY 012.JPG (126.32 KiB) Viewed 4989 times
HMS SUPPLY 013.JPG (125.09 KiB) Viewed 4989 times
HMS SUPPLY 014.JPG (130.85 KiB) Viewed 4989 times
Who is online
Users browsing this forum: No registered users and 5 guests
