Enterprise 1799
Moderators: Aussie048, zoly99sask
Post Reply
probablynot
Petty Officer Second Class
Enterprise 1799
Post by probablynot » Wed Jun 05, 2013 5:33 pm
deleted
StevieF
Re: Enterprise 1799 (Constructo kit) by Probablynot
Post by StevieF » Thu Jun 06, 2013 4:27 am
That looks a nice little kit to learn some extra skills on!!
Don't be daunted, the learning curve in this hobby is quite rapid especially when there are all the build diaries to take examples from. I would suggest that you look at as many forums that you can find and see what other builders do?
With regard to a build jig the simplest is a base board with metal angle brackets screwed to it, I am including a couple of photos of one I used for my Victory build.
For my build board I used a shelf, and when I needed the extra room for other tasks I simply rested it on its brackets out of the way.
I hope that helps a little, cheers, Steve.. :text-welcomewave:
probablynot
Post by probablynot » Thu Jun 06, 2013 4:46 am
deleted
User avatar
GaryM
Senoir Chief Petty Officer
Post by GaryM » Thu Jun 06, 2013 12:16 pm
That is pretty clever Steve. I have extra shelves so I think I can do that for my next build. Thanks.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
probablynot
Re: Enterprise 1799
Post by probablynot » Thu Jun 06, 2013 2:06 pm
deleted
StevieF
Post by StevieF » Fri Jun 07, 2013 6:16 am
probablynot wrote:Now the first dabs of glue have been applied, and the build is under way.
[Jig, to hold the keel straight and true, © StevieF. Thanks, Steve!]
I'm glad that I could help out! if you ever need any sort of guidance just post it I'm sure someone will come to the rescue with a worthwhile answer?
Cheers, Steve.. :)
User avatar
otrax01
Petty Officer First Class
Post by otrax01 » Fri Jun 07, 2013 10:14 am
Brian if you also check out Steve's build log, "Steves Sovereign Build Partwork" in the kits forum you'll see the neat way he used lego to keep his frames aligned with the keel. Have a good build.
Kent
Remember, When your out in the shop, Ship Happens!
___________________________
Finished Builds: Le Mirage by Corel
Current Build: HMS Victory by Mamoli
probablynot
Re:
Post by probablynot » Sun Jun 30, 2013 11:42 am
deleted
probablynot
Re
Post by probablynot » Tue Jul 30, 2013 3:26 pm
deleted
User avatar
JScolum
Petty Officer Third Class
Post by JScolum » Sat Aug 10, 2013 6:28 pm
Post Reply
