Bounty by Amati
SgtGlick
Petty Officer Third Class
Bounty by Amati
Postby SgtGlick » Wed Feb 27, 2013 2:44 pm
Ahoy fellow shipmodelers;
I am about to start a build of the Bounty by Amati.
I have a building board.
Two adjustable guide rails to fit any center keels.
An adjustable clamp to hold any center keel vertical to the
building board base.
Clamp also has provision to hold the bulkheads vertical to the
base.
I will be posting photos later.
I will also be posing a question or two re; procedure.
Sgt Glick :cool:
User avatar
Donnie
Senoir Chief Petty Officer
Contact:
Re: Bounty by Amati
Postby Donnie » Wed Feb 27, 2013 4:43 pm
Good - can't wait to see it happen !
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
SgtGlick
Re: Bounty by Amati
Postby SgtGlick » Wed Feb 27, 2013 5:11 pm
Going to upload a few photos.
Sgt Glick. :cool:
P.S.
Should I install the first ( bow end) bulkhead first?
or the last (stern end) first?
SgtGlick wrote:Ahoy fellow shipmodelers;
base.
Sgt Glick :cool:
User avatar
GaryM
Re: Bounty by Amati
Postby GaryM » Wed Feb 27, 2013 6:37 pm
I love Amati fittings. They do great detail casting. Will love watching this one. Good luck.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
SgtGlick
Re: Bounty by Amati
Postby SgtGlick » Wed Feb 27, 2013 8:06 pm
Hi Gary,
thanks for the encouragement.
Sgt Glick :cool:
GaryM wrote:I love Amati fittings. They do great detail casting. Will love watching this one. Good luck.
User avatar
Donnie
Contact:
Re: Bounty by Amati
Postby Donnie » Wed Feb 27, 2013 10:49 pm
I don't think it really matters and I was thinking about my own project back then. It seems to me that I started in the middle with one and made sure it was aligned as good as I could. Then it seems that I put some at random going fore and aft, until I felt things were tightening up, then I just filled in the rest. I guess there is no pattern - but you gotta be square in several dimensions.
i.e. measure from the base of your table up to the top of the Bulkhead on each side - clamp things down and put a good coat of slow drying WOOD glue. Do not use and I might want to be as bold as to say never use CA on this part. You have to be able to position things around as the glue cures. That frame is the most important part of making a good true hull that can be "faired" easily.
BTW - good to see you working on a project.
Donnie
ps. I always tell people to turn their frame upside down on a flat table when you finished installing the Bulkheads - then observe the corners of the frame to make sure the upper tips of the frame are all touching - the point is that you don't want your frame to rock back and forth on the table. I thought I had a square frame until I flipped mine over to start my hull planking only to find out I was like 1/8" off - the frame rocked.
No Guts, No Glory !
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Re: Bounty by Amati
Postby Anja » Thu Feb 28, 2013 12:25 am
Hello SgtGlick,
Welcome back, it's indeed good to see you started a build.
Nice building board.
Good luck with this build and take care,
Anja
Those we loved but lost are no longer where they were,
but are always where we are.
Current build - De Halve Maen by Corel
viewtopic.php?f=52&t=235
Completed : Albatros 1840 by Constructo
SgtGlick
Re: Bounty by Amati
Postby SgtGlick » Thu Feb 28, 2013 11:08 pm
Thanks, Anka,
Going to add some more progress.
Sgt Glick :cool:
Anja wrote:Hello SgtGlick,
Anja
Did not realize I could add comments :)
Added false keel
Rubber bands, and Modelmaker's T pins.
Cementing when I am happy with the structure.
Who is online
Users browsing this forum: No registered users and 4 guests
