Billing Boats AmericA 1:72 scale
User avatar
popeye
Master Chief Petty Officer
Contact:
Postby popeye » Thu Feb 14, 2013 10:57 pm
I started this build on the 29th of December. I was waiting for paints, woods, and other supplies. since this kit will be built out of the box, it can be done with what I have. I don't see a whole lot that needs to be bashed.....except for the skylight, and perhaps the grating. everything is going to feel like i'm moving at light speed, but it will calm down as soon as I get the build caught up. if you wish to read the build log I done on this ship, you can find them here:
http://wenzelswharf.wordpress.com/2012/ ... scale-kit/
this kit is a fairly new release
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Re: Billing Boats AmericA 1:72 scale
Postby popeye » Thu Feb 14, 2013 11:05 pm
this is a split keel assembly. it was kind of a problem figuring out the rib numbers, but once I did, it went OK. I did find a problem with one of the ribs, but that was an easy fix as well. this was done on the 30th of December.
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Thu Feb 14, 2013 11:10 pm
the 31st of December.......day time.....new years festivities! the hull assembly.
how I did the stern transom ribs
the rudder
bow rabbits
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Thu Feb 14, 2013 11:14 pm
December 31st....daytime........the deck planking
two coats of lacquer
trimmed and sanded
the tiller floor
stern deck halves
the bow sections
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Thu Feb 14, 2013 11:20 pm
December 31st....night time.....the count down to the new year. I did mar the deck with water......goofy me......but a coat of lacquer later, and it was just fine.
another coat of lacquer later
never use water on fresh lacquer to clean a white glue spot
center border cemented in place
cementing on the aft sections
cementing on the fore sections
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Thu Feb 14, 2013 11:30 pm
I didn't get back to working on it till the 11th of January. hull planking begins the planking wasn't that good.....looked like it was cut with a dull blade. I sanded the edges and beveled the mating edge, and it went fairly well. where this is to be a wood hull, I allowed some of the plank lines to show up. after the hull was sanded, it came out pretty smooth. if you wish to see what the planks looked like, I did add it into the build log......you can read about it there.
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Thu Feb 14, 2013 11:34 pm
on the 12th of January, I did the balsa cap for the transom......sorry folks, but I have a dislike for balsa, in this medium. I had my problems with it, but I mixed up some sawdust and white glue, and I was able to repair the non-conformity
after I fixed it up
before I fixed it up
you can see the Denny-Zen in the background.....this was a while ago
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Thu Feb 14, 2013 11:41 pm
I sanded the hull quite a bit.......my arms were tired. I decided to work on the deck fittings. I did away with the skylight structure plug. I created the structure, making it appear hollow. after the roof was cemented together, I will fill in the openings with the window maker and make the glass for them. with the inside of the skylight painted flat black, it will appear as though the inside is an open area.
some of the parts painted up
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Thu Feb 14, 2013 11:49 pm
this past bit of progress was done on the 15th of January.....here is the rest of it
the tiller seat assembly
improved grating using the plastic parts
what they want you to use for the grating
companionway almost finished
the tiller seat and the trim ring
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
User avatar
popeye
Contact:
Postby popeye » Thu Feb 14, 2013 11:57 pm
this was done on the 18th of January. this should bring the build to the present.
I have more progress to report on this build....I should have it up shortly. I pulled myself away from the lobsie twins, so I could do some work on it.
it's not a lot of progress at this point, but I'll make up for it on the next posting.
the top rails.....note the scarf joint
I lost this part some time ago...I couldn't find it and wrote it off for a loss. I found it on I think, the 16th
finished builds:
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
Holiday Harbor
Titanic
Who is online
Users browsing this forum: No registered users and 1 guest
