Midwest Maine lobster boat - 3/4" to 1' scale
Moderators: Aussie048, zoly99sask
popeye
Master Chief Petty Officer
Contact:
Re: Midwest Maine lobster boat - 3/4" to 1' scale
Postby popeye » Sun Apr 14, 2013 7:02 pm
thanks Gary.....the only thing left to do on this one, is the skis... I want to get on the AmericA build, so I'll do them in between every thing . thanks for looking in and the good word! ;)
popeye
Contact:
Postby popeye » Wed Feb 19, 2014 9:12 pm
I know it has been a while.......I have gone on a walkabout.....I have done many things. of course......winter has not been kind to me......the snow is a pain in the....well, you know where :D I left this build off with the Phylly C still needing to be finished....the skis. I tried a few ideas, but could not come up with a convincing set of bindings. not only that, I've called Barbie numerous times.....she won't call me back! so I've had to rely on my chief Wharfsman, Chester. tried to get him to model the skis, but, with his club feet {way too much time on deck}, it was impossible to get a good fit. so I thought up another way to add them to the build, and finish it off.
these are the skis.....tired of them hanging around
here is my chief Wharfsman, Chester
popeye
Contact:
Postby popeye » Wed Feb 19, 2014 9:19 pm
So......to start this off, I guess I should spill the beans. I figure that if I can't portray them openly on deck, I might as well portray them stored in their ski rack. I had to make it so that the other side of the skis couldn't be seen, so the rack was built deep, and as close a tolerance as possible.
the main framework of the rack - dry fit
the center divider was added to the rack
popeye
Contact:
Postby popeye » Wed Feb 19, 2014 9:30 pm
the rack was shaped and sanded.......the bottom of the rack was closed in. I knew I still had some of the wainscoting around that I used inside the helm, but I couldn't find it......so I just laid some planking I had lying around. after the dry fit.......I added some molding to mimic the interior. later, it was given a couple of coats of semi gloss lacquer.
wainscoting added to the bottom of the rack.
moldings added
dry fit to see how it looked
stained a medium walnut and sealed with semi gloss lacquer
skis in for a reality check. had to add a piece of wood in the bottom of the rack to get them to come forward
the adjustment was made and I drilled the holes for the eye bolts {not glued in yet}
popeye
Contact:
Postby popeye » Wed Feb 19, 2014 9:37 pm
time to add the hardware.......not too much really. took some antiqued chain that I had and set it into the existing eye bolts......equally, with a little hang to them. with another couple of eye bolts, I made up some hooks and set them onto the other end of the chain. all of the eye bolts were then cemented in place {except for the hooks, of course}, and then cemented the assembly in place on deck.
the chain hardware installed
the skis were cemented in place and allowed to dry for a short time. the hooks were fastened
a shot of the Phylly C without the rack
....and a shot of her with the rack installed
a close up of the helm
popeye
Contact:
Postby popeye » Wed Feb 19, 2014 9:40 pm
:greetings-clapyellow: there! they are off my table.......and where they belong!
I am pleased! :character-beavisbutthead:
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Thu Feb 20, 2014 4:27 pm
That makes a nice addition. Looks like it belonged there all the time.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
popeye
Contact:
Postby popeye » Thu Feb 20, 2014 5:44 pm
thanks Gary.....good to have finally found a home for them. I got tired of them being on the table.....that 'I'll do it tomorrow' thing really worked well.....I put them away. when I went to actually get down to doing it, I couldn't remember where I had put them. just nice to know the boat is complete now.
do you have a build going on at the moment? I looked for one and didn't see.
User avatar
otrax01
Petty Officer First Class
Postby otrax01 » Sat Feb 22, 2014 1:25 am
Clever way to get around the problem, but I say they look great either way. Nice job on the build.
Kent
Remember, When your out in the shop, Ship Happens!
___________________________
Finished Builds: Le Mirage by Corel
Current Build: HMS Victory by Mamoli
popeye
Contact:
Postby popeye » Sat Feb 22, 2014 9:16 pm
thanks Kent.....that's what I like about this hobby. there more than one way to skin a cat!
Who is online
Users browsing this forum: No registered users and 4 guests
