San Felipe 1690 - Panart
Moderators: zoly99sask, Aussie048
User avatar
carlosys
Petty Officer Third Class
Contact:
Re: San Felipe 1690 - Panart
Post by carlosys » Sat Apr 20, 2013 2:06 am
Hi
I'll start with the gun ports on the port side.
To do this I placed masking tape over the area where the gun ports go to dial without fear.
The gun ports review has to be done so that it is symmetrical and aligned.
Eventually, after some hours staking is done. Now it start drilling and cutting. "Only" are 49 per port and starboard 49 :? so I will have a few days entertaining.
Regards
Carlosys Ship Modeling________________________________________________________________________
Completed:J.S. Elcano | Diorama Bote Auxiliar Nepo | Frigate Diana | King of Mississippi | Bot de Llum
Current build: San Felipe 1690 de Panart
User avatar
GaryM
Senoir Chief Petty Officer
Post by GaryM » Sat Apr 20, 2013 2:46 pm
Looking pretty nice. Great job.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
StevieF
Petty Officer Second Class
Post by StevieF » Sat Apr 20, 2013 3:02 pm
Looking very good!
I like the idea with the masking tape to mark the gunports, consider that tip copied!!
With my Sovereign build I am led to believe that the provided decking planks will be lime wood, .5x5mm. I intend to use tanganyika .5x3mm, in a three shift system.
Keep the updates coming, you should have a very good looking model when it's finished
All the best, Steve.. :text-thankyouyellow:
cog
Post by cog » Sun May 05, 2013 6:05 am
As you, I haven't been around lately, due to personal circumstances. However, you have made some major advancement. I like the way you did your decks - have to keep that one in mind - and also the method for the gun ports.
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
Next build: (on the shelf) Arno XI
popeye
Master Chief Petty Officer
Contact:
Post by popeye » Mon May 06, 2013 7:29 pm
that's some really neat stuff you've done there! ;)......nice planking!
User avatar
Donnie
Contact:
Post by Donnie » Fri May 10, 2013 2:11 pm
Eccellent method of layout on the Gun Ports, etc. Very nice progress - some really good workmanship here !!! :greetings-clapyellow:
Donnie
Current Build: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
"War Ships are safe at harbor, but that is not what they were made for"
User avatar
carlosys
Contact:
Post by carlosys » Sun Jun 23, 2013 1:25 pm
Thank you very much to all for your comments :text-thankyouyellow:
Apologize for the last few weeks of absence. I've been (and I) quite busy at the gigs and I can not devote many hours these days.
I started with the gun ports port and the idea was to let these facts loopholes frames with some "depth" to make it look once painted the effect of "bulk" of the hull, since the wall at that point is only 1 , 5mm.
The problem begins in the implementation of these frameworks. I tried 1mm (too thin), 2mm (too thick) .. I made a template, mold, etc ... but were not exactly the same.
The idea is to make a square tube frames far and go mode cutting slices. In this way, everyone is equal and then with the second liner, dissimulation possible defects in the pocket.
Now I only doubt what color I paint the frame ... red, walnut, etc ...
With picture is clearer but not much mystery.
This is what you need to get
The wood that will square tube and gluing process. This helped me a aluminum profile measures slightly smaller, but perfectly aligns the slats.
With the circular saw (gift :) ) cut the "slices" of the gun ports
Here the first of 13x11 port side. Those that are not done yet deck the area that are somewhat larger.
Simulation second plank
Regards
edmay
Post by edmay » Tue Jul 16, 2013 12:19 am
Hello Carlos,I will be getting this model soon,and will follow your log in a third row seat if you do not mind,your Felipe is neatly built,good photo"s and clearly explained,the method used for your gunports is brilliant,thank you for the learning.Happy modeling . Edwin .http://www.shipsofscale.com/phpBB3/post ... f=52&t=341#
User avatar
Donnie
Contact:
Post by Donnie » Mon Jul 29, 2013 3:37 pm
Carlos,
Now - that is some clean work done on those port frames ! Very nicely executed ! What kind of table saw ?
Donnie
Donnie
User avatar
carlosys
Contact:
Post by carlosys » Sun Aug 11, 2013 3:48 am
Donnie wrote:Carlos,
Donnie
Thanks Donnie. The table saw is very simple. The PROXXONKS-230
Regards
Post Reply
