San Felipe 1690 - Panart
Moderators: zoly99sask, Aussie048
User avatar
carlosys
Petty Officer Third Class
Contact:
Re: San Felipe 1690 - Panart
Post by carlosys » Sat Feb 16, 2013 3:37 am
Thank's Cog for your comment.
Here we follow the lining around the San Felipe and the theme of the "loophole" :?: .
The template that comes with the kit indicates the position of the barrel, but after going to a plastic template to see how it corresponds with reality, surprise, that template is not as accurate as one would expect.
I think that's one of the reasons that in version 2.0 and no pin kit for longitudinal profiles cannons but also that part of the loopphole's is preformed:?
In any case, this is not going to be able to me. So I anticipate some assembly steps pulling up bulwarks to find a good reference for the "new" template that I do.
So things are.
Detail of the bulwark area then should be cut, that makes the strakes are not stuck to them so you have to be careful because not completed until the outer and inner lining, they are fragile.
On the other hand, shot some firecrackers "masterpieces" down to make better references for the template of the guns.
Nightmare stakeout and location of loophole :sad: I do not quite understand it because that area had been precut with the locations of the locks, so that there can be no error on my part.
Anyway, I have the theme almost ready and just have to redo the template for port and starboard and forget surprises later.
Regards
Carlosys Ship Modeling________________________________________________________________________
Completed:J.S. Elcano | Diorama Bote Auxiliar Nepo | Frigate Diana | King of Mississippi | Bot de Llum
Current build: San Felipe 1690 de Panart
User avatar
Sjors55
Chief Petty Officer
Chief Petty Officer
Post by Sjors55 » Sat Feb 16, 2013 8:13 am
You make some great progress Carlos.
Everything looks just great!
Sjors
Whatever you do will be insignificant, but it is very important that you do it.
(Mahatma Gandhi)
Current build:
Le Mirage by Corel (1:75)
Current build: San Ildefonso by OcCre (1:70)
http://www.shipsofscale.com/phpBB3/view ... f=52&t=279
User avatar
wim500
Petty Officer Second Class
Post by wim500 » Sat Feb 16, 2013 3:35 pm
Carlos, nice progress so far.
In my opinion the San Felipe is a very beautiful ship and I will follow your build frequently.
Regards,
Wim
popeye
Master Chief Petty Officer
Contact:
Post by popeye » Tue Feb 19, 2013 1:02 pm
very nice build so far! nice and clean.....looks like some good quality wood.
User avatar
Donnie
Contact:
Post by Donnie » Wed Feb 27, 2013 4:56 pm
this kit looks like it is very well made and a great builder to go along with it. This is going to be a really nice ship to see come alive. I sure wish I had my Trinidad finished, I think I would dive into this one myself.
Donnie
Current Build: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
"War Ships are safe at harbor, but that is not what they were made for"
User avatar
carlosys
Contact:
Post by carlosys » Thu Feb 28, 2013 1:27 pm
Thank you Donnie, Popeye, wim500, Sjors55 for your comments, this gives encouragement to go ahead with the model.
:text-thankyouyellow: :text-thankyouyellow: :text-thankyouyellow:
cog
Post by cog » Sat Mar 02, 2013 7:26 am
You are going fast. I like the method you use to get the gun ports drawn on the hull
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
Next build: (on the shelf) Arno XI
User avatar
Donnie
Contact:
Post by Donnie » Tue Mar 05, 2013 12:14 pm
I had the same problem with my Gun Port openings that were laser cut (one strip). things just did not line up the way i thought they should - so I recut them.
Donnie
User avatar
otrax01
Petty Officer First Class
Post by otrax01 » Thu Mar 28, 2013 12:36 am
This looks like it's going to be a hell of a build. Very nice job so far. I'm looking forward to following your progress for however long it takes you.
Kent
Remember, When your out in the shop, Ship Happens!
Finished Builds: Le Mirage by Corel
Current Build: HMS Victory by Mamoli
User avatar
carlosys
Contact:
Post by carlosys » Sat Apr 20, 2013 1:54 am
Hi
Forgive my absence the last few weeks. Lack of time is always a problem :text-imsorry: .
I put the progress of San Felipe
The decks must be made of strips of 3mm. To my mind a bit small, so I will desist from nail simulate because I think it will look good.
The latter has given me a lot of work because I had to pretty much do everything with tweezers because it did not fit my hands.
The slats are attached with white glue slightly diluted.
Lined with walnut bulwark 1.5 mm inside it.
San Felipe current appearance without "polished and embellished." It remains to treat deck, reviewing helmet, etc, etc ...
Regards
Post Reply
