Sovereign of the Seas by Sergal/Mantua
User avatar
Donnie
Senoir Chief Petty Officer
Contact:
Re: Sovereign of the Seas by Sergal/Mantua
Postby Donnie » Tue Dec 18, 2012 4:57 pm
This is one ship that I only have dreamed of building. I am not sure if I can tackle this one or not. Seems quite daunting. At any rate, it seems that you are off to a great start on your Build Log. I assume that you are going to use simple wood glue to glue the frame. I know that I did. The reason is that you can make adjustments to the alignment before the glue dries.
I know everybody gets tired of me saying this, but make sure you turn your frame/hull upside down and see if all the "highest points" of the frame are touching evenly on a flat surface. I did not do this. Then one day while I was working on the frame, I decided to flip that hull/frame upside down only to see that one corner of the frame was like 1/8" floating off the table. In other words, the frame would "rock back and forth" - oh well, it was done now - so I had to move on. Any distortions even a little twist can make this one error accumulate with problems as you move along. For instance the planking might have problems.
:twocents-02cents: Oh, well, just my 2 cents worth.
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
User avatar
GaryM
Postby GaryM » Tue Dec 18, 2012 11:16 pm
I used Titebond 2 or 3 to glue the frames. 2 does not set as fast as 3 but 3 is a stronger bond. 2 takes about 20 to 30 minutes, depending on amount applied, to set firmly enough where movement would destroy some of the final bonding strength. Titebond 3 sets in about half that time. Both have a 24 hour final cure time.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
SgtGlick
Petty Officer Third Class
Postby SgtGlick » Wed Dec 19, 2012 2:17 am
Hi Gary,
I use Weldbond for the bulkheads.
Joints soaked in alcohol can be loosened to fix errors.
CA for "tacking"
Sgt Glick :cool:
GaryM wrote:I used Titebond 2 or 3 to glue the frames. 2 does not set as fast as 3 but 3 is a stronger bond. 2 takes about 20 to 30 minutes, depending on amount applied, to set firmly enough where movement would destroy some of the final bonding strength. Titebond 3 sets in about half that time. Both have a 24 hour final cure time.
User avatar
Anja
Chief Petty Officer
Chief Petty Officer
Postby Anja » Wed Dec 19, 2012 11:00 am
Hello Sgt Glick,
Another beautiful build. I wish you luck with this build and happy modeling.
Take care,
Anja
Those we loved but lost are no longer where they were,
but are always where we are.
Current build - De Halve Maen by Corel
viewtopic.php?f=52&t=235
Completed : Albatros 1840 by Constructo
User avatar
GaryM
Postby GaryM » Wed Dec 19, 2012 12:35 pm
Hello Sgt Glick:
Interesting how everyone has their favorite way of handling the same item. You said "Joints soaked in alcohol." This has the advantage of preparing your sailors for their drinking days. :text-lol:
Happy modeling,
Gary Maple
SgtGlick
Postby SgtGlick » Wed Dec 19, 2012 4:36 pm
Hi Gary,
Do you realize you gave yourself away?
By mentioning sailors in connection with ship models,
you let me know you are really into it :cool:
Sgt Glick
GaryM wrote:Hello Sgt Glick:
User avatar
Donnie
Contact:
Postby Donnie » Wed Dec 19, 2012 5:01 pm
I am waiting to smell the woodglue on the frame !!! :handgestures-thumbup:
No Guts, No Glory !
SgtGlick
Postby SgtGlick » Wed Dec 19, 2012 5:05 pm
Not until I know for sure where the gun posts go.
Sgt Glick :cool:
Buried in research..... ;-)
Donnie wrote:I am waiting to smell the woodglue on the frame !!! :handgestures-thumbup:
User avatar
Sjors55
Chief Petty Officer
Chief Petty Officer
Postby Sjors55 » Wed Dec 26, 2012 1:23 pm
Hi SgtClick,
Welcome :D
I will follow you also on this one because this one is on my wish list.
First I have to finish the Mirage and the San Ildefonso and then I have to look very lovely to Anja and maybe this is gonna be my next project.....
Enjoy your build and let us see what you are doing....
Sjors
Whatever you do will be insignificant, but it is very important that you do it.
(Mahatma Gandhi)
Current build:
Le Mirage by Corel (1:75)
Current build: San Ildefonso by OcCre (1:70)
viewtopic.php?f=52&t=279
SgtGlick
Postby SgtGlick » Thu Dec 27, 2012 1:51 am
Hi Steve,
Thanks for the good luck wish.
Sgt Glick :cool:
Who is online
Users browsing this forum: No registered users and 2 guests
