Dolphyn - Corel
Moderators: Aussie048, zoly99sask
Post Reply
cog
Petty Officer Second Class
Dolphyn - Corel
Post by cog » Mon Dec 10, 2012 7:30 am
I got the model some odd 15 years ago from someone whom started the basics and never got around finishing it. So I had a box full of wood and a crooked frame. Certainly nothing fancy like today's laser cut parts!
I took it all apart and restarted. Unfortunately I forgot to make some pictures at the very beginning (1st mistake!) But fortunately not to late to start the build log.
Another problem I encountered during the build - thanks to an old kit, partly on the go - you might miss parts, or parts are broken ...
So let's get started:
After ripping the base apart, i.e. remove decks, and trusses, I could rebuild. Needed to cut one new truss, as I ripped one a bit to enthousiastically ... After that I realigned the keel and rebuild the base.
User avatar
barba
Petty Officer First Class
Re: Dolphyn - Corel
Post by barba » Mon Dec 10, 2012 8:36 am
Welcome Cog, put some pictures, and I wish you luck with the build.
barba
User avatar
GaryM
Senoir Chief Petty Officer
Re: Dolphyn - Corel
Post by GaryM » Mon Dec 10, 2012 1:40 pm
Hopefully all the important pieces are there. Even with a good scrool saw, building the old kits can be tricky. Lots of file work after cutting out the pieces. Wish you luck and look forward to pictures.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
cog
Re: Dolphyn - Corel
Post by cog » Tue Dec 11, 2012 2:49 pm
Thanks barba and gary,
I need to find a way to show the pictures. I'm not prepared to put my images on a public server. I know it will make posting difficult.
Carl
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
Next build: (on the shelf) Arno XI
User avatar
Donnie
Master Chief Petty Officer
Contact:
Re: Dolphyn - Corel
Post by Donnie » Fri Dec 14, 2012 9:00 pm
Carl,
you don't have to have an image hosting website to upload photos on SoS. If you scroll down just a little while "writing" your post, you will see
""If you wish to attach one or more files enter the details below."" Then a Browse Dialog Box button to click on that and select your picture from your own PC. Then click on "Add the file".
Then when you "preview" your post, you should see your image you just uploaded. Then click on submit. You do not have to select "place image inline". Just load your file then go. The SoS Server will take care of it.
Donnie
Current Build: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
"War Ships are safe at harbor, but that is not what they were made for"
cog
Re: Dolphyn - Corel
Post by cog » Sat Dec 15, 2012 12:11 pm
Thanks Donnie,
I must have overlooked that possibility :oops:
Carl
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
User avatar
Donnie
Contact:
Re: Dolphyn - Corel
Post by Donnie » Sun Dec 16, 2012 12:22 am
Hey Carl - no worries ! I put this forum together and even I forget its there. No bragging here though - it took a while for me to figure this out. (and I still have a long way to go). I try to leave well enough alone on this forum. In other words - I am very careful with modifications.
cog
Re: Dolphyn - Corel
Post by cog » Wed Jan 09, 2013 3:19 pm
Finally, I'll be posting. First images of the kit after the ripping apart and remounting the bulkheads and deck, and subsequently first layer of planks.
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
cog
Re: Dolphyn - Corel
Post by cog » Wed Jan 09, 2013 3:23 pm
During planking, whilst waiting for them to dry, I had a go at the gratings. Corel's strips included for them makes it a fairly easy. It is a pitty there are only 4!
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
cog
Re: Dolphyn - Corel
Post by cog » Wed Jan 09, 2013 3:27 pm
Second layer, gave some colour to the hull. It looks less a carcas ;-)
Cheers,
Carl
Current build:
Kit
Dolphyn - Corel
Scratch
Sea Witch
Post Reply
