HMS Pegasus, 1/64 VM/Amati
Moderators: Aussie048, zoly99sask
rdsaplala
Petty Officer Second Class
Post by rdsaplala » Wed Jun 06, 2012 7:24 am
Hi to all :D
I just finished my HM Brig Badger and was really looking forward to building a frigate, particularly Jotika's HMS Surprise but I don't know when they will ever release it so I got HMS Pegasus instead... she's not a frigate but her lines and ornaments are just as beautiful, plus from afar, she has the look of a little frigate ;-)
OK, enough talk, time to build my "Peggy Sue"...
Bulkheads fitted quite nicely and the kit had a 5mm lower deck which when fitted, kept everything straight and true... kudos to the designer Chris Watton for that :8)
Being made of MDF, these were also relatively easier to fair with my trusty craftknife and some sanding sticks.
They were however more fragile compared to regular ply.. being a heavy handed clutz, I have to be extra careful :shock:
-Aldo
Current Build:
Amati HMS Pegasus
: http://www.shipsofscale.com/phpBB3/view ... f=52&t=261
Finished Build:
Caldercraft HM Brig Badger
: http://www.shipsofscale.com/phpBB3/view ... f=52&t=205
rdsaplala
Re: HMS Pegasus, 1/64 VM/Amati
Post by rdsaplala » Wed Jun 06, 2012 7:25 am
The build continues...
Before first planking, the instructions would first have you attach the false deck, plank it and attach the capstan and some bitts. I decided to just attach the false deck first then went on to attach the gunports and do the 1st planking ;-) I will plank the deck and attach the fragile fittings once I'm done with the heavy handed planking work.
The gunports were quite wide so I was apprehensive of using them but after some soaking in boiling water, they turned out to be obedient little darlings :lol: either that or they gave in to my "brute force" :twisted: Yep, I guess the pins showed them who's boss as they quietly followed the bulkhead shapes, especially the tumble home after all the pinning :twisted:
Pinning the gunports to the bulkheads however resulted to 2 main problems:
First, they produced holes on the bulkheads that have to be filled...
More importantly, the protruding pins caused the modeller some occasional blood loss...OUCH! :shock:
Good thing it was just first planking, that red stain would have looked awful on the 2nd planking :lol:
Oh by the way, hard learned lessons from past builds thought me that some parts just LOVE to break during planking so I protected them to make sure they stay intact, the Admiral thinks it's overkill, but I say better safe than sorry ;)
Notwithstanding the giant pack of dressing on the stem, the tumblehome turned out OK so I guess all that pinning and blood loss was worth it :lol:
-Aldo
Current Build:
Amati HMS Pegasus
Finished Build:
rdsaplala
Post by rdsaplala » Wed Jun 06, 2012 7:30 am
One last batch of updates...
First planking proceeded without much problem, other than me breaking all the proper planking rules on spiling :oops:
I'll try to be more correct on the second layer, in saying "more correct", I mean only 95% of the planks will have pointy ends :lol:
Time to attach the stern counter, of course pre-shaped using my hi-tech shaping jig, namely whatever rounded object I could find :lol:
First planking and stern counter done, time to start second planking.... I started it at the level of the wales, needless to say, I had a "whale of a time" attaching it :lol:
First walnut plank temporarily pinned (no biggie as it will be covered by the wale anyway),then finalized using superglue.
Symmetry check at the bows, again I'm happy with the tumblehome curve, though not happy with the "belly curve" of the builder, someone should tell that guy to go on a diet! :lol:
And finally, here are the last few pictures showing my current stage of build.... all 3 walnut planks attached, corresponding to level of the wale. I also used 0.5mm thick walnut to plank over the stern counter prior to 2nd planking.
That's it for now, will post new updates once I get some significant work done :D
-Aldo
Current Build:
Amati HMS Pegasus
Finished Build:
Anja
Chief Petty Officer
Chief Petty Officer
Post by Anja » Wed Jun 06, 2012 11:21 am
Hello Aldo,
Looking good and very fast progress. Never mind how the first planking will look, just make sure you get a nice smooth surface for your second planking.
I think the guys are too scared to tell you. So, let me be the one to tell you: 'Go on a diet'. You asked for it.
Take care,
Anja :happy-sunshine:
popeye
Master Chief Petty Officer
Contact:
Post by popeye » Wed Jun 06, 2012 11:52 am
great start on Peg, Aldo! very cleanly assembled so far. I wish you fair winds on her build! ;-)
User avatar
GaryM
Senoir Chief Petty Officer
Post by GaryM » Wed Jun 06, 2012 12:55 pm
Very nice start. The first palnking does not matter and makes for a stronger hull if it does not match the second planking. Like Anna says, smoothness is what is important.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
Sjors55
Chief Petty Officer
Chief Petty Officer
Post by Sjors55 » Thu Jun 07, 2012 3:33 am
Hi Aldo,
You are going fast!
Do you want to finished her at the end of the month?
It looks great.
Make me enjoy :D
And yes, you have to go to a diet.....
Sjors
Whatever you do will be insignificant, but it is very important that you do it.
(Mahatma Gandhi)
Current build:
Le Mirage by Corel (1:75)
Current build: San Ildefonso by OcCre (1:70)
http://www.shipsofscale.com/phpBB3/view ... f=52&t=279
rdsaplala
Post by rdsaplala » Sun Jun 17, 2012 8:30 am
Hello Anja, Popeye, Gary and Sjors, thanks very much for the kind comments, much appreciated :grin: Oh, and thanks for the reminder Anja, this builder will go on a diet :handgestures-thumbup:
A little bit of progress. So far I have completed second planking from the wale down to the keel. This is my first attempt at planking in a "shipwright" manner so there is room for improvement. Hopefully, it will look better when I get to my 10th ship :lol:
-Aldo
Current Build:
Amati HMS Pegasus
Finished Build:
User avatar
GaryM
Post by GaryM » Sun Jun 17, 2012 2:03 pm
Very nicely done. Great job on the diminishing and expanding joint work. Well worth the effort even if you paint it lightly.
Happy modeling,
Gary Maple
Børge
Petty Officer First Class
Post by Børge » Sun Jun 17, 2012 3:29 pm
Hi Aldo
Catching up on your Pegasus. :handgestures-salute:
You have done a very good job so far.
The sec planking looks supernice.
Will you paint the hull, or keep it natural.
Børge
__________________________
Current build(restore, bashing)
BB582 "Dragen" Scale 1:12
On hold: BB534 Bolougne Etaples Scale 1:20
Not started: Model Shipways MS2040 USS Constitution 1:76
If life is ike a box of chocolate EAT IT :)
Post Reply
