Build Log: US Niagara
Moderators: Aussie048, zoly99sask
User avatar
bbrockel
Petty Officer Second Class
Post by bbrockel » Wed May 09, 2012 8:09 pm
Started this build a little over a year ago. To date the hull has been planked, filled, sanded and primed. The upper bulwarks have been planked and gun ports shaped and painted. Ready to mark the waterline and paint the hull.
Niagara Build 121.jpg (74.1 KiB) Viewed 4168 times
Niagara Build 116.jpg (84.88 KiB) Viewed 4168 times
Niagara Build 113.jpg (81.8 KiB) Viewed 4168 times
Niagara Build 110.jpg (77.9 KiB) Viewed 4168 times
Niagara Build 109.jpg (79.72 KiB) Viewed 4168 times
Niagara Build 083.JPG (85.47 KiB) Viewed 4168 times
Niagara Build 081.jpg (95.49 KiB) Viewed 4168 times
Niagara Build 028.jpg (75 KiB) Viewed 4168 times
Niagara Build 006.jpg (62.67 KiB) Viewed 4168 times
Niagara Build 002.jpg (63.75 KiB) Viewed 4168 times
And so it begins.
Niagara Build 001.jpg (59.29 KiB) Viewed 4168 times
popeye
Master Chief Petty Officer
Contact:
Re: Build Log: MS Niagara
Post by popeye » Wed May 09, 2012 8:16 pm
there you go Bob!!! you started your first piece of real estate! glad to be able to follow your build here! will look forward in seeing more! :D :D :D
User avatar
bbrockel
Post by bbrockel » Wed May 09, 2012 8:22 pm
Thank you my friend. Will definitely post more as I progress. Now on to the MS Syren build log. :D
popeye
Contact:
Post by popeye » Wed May 09, 2012 8:33 pm
I was going to ask this earlier.....but due to the circumstances, I hesitated. are you going to bring your other ship {I forgot which one} to your home and finish it there?
User avatar
GaryM
Senoir Chief Petty Officer
Post by GaryM » Wed May 09, 2012 9:12 pm
Looks like a great start.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
bbrockel
Post by bbrockel » Wed May 09, 2012 11:44 pm
Gary, Thank you.
Popeye, you are correct. I'm in the process of moving into my new location, my Dad's house. I will finally have both builds under one roof. Just getting the house and shop set up is going to take a while. Hae reserved a U-Haul truck for the weekend of May 19th and I have take the following week off at work. Should be pretty well settled in by the end of May. At least that's my plan. We will see. "The best laid plans of mice and men....."
Anja
Chief Petty Officer
Chief Petty Officer
Post by Anja » Thu May 10, 2012 1:23 am
Hello Bob,
Thanks for sharing this build log! You're off to a good start.
Looking forward to seeing more of your progress.
And good luck with the move.
Take care,
Anja :happy-sunshine:
popeye
Contact:
Post by popeye » Thu May 10, 2012 6:13 am
sounds like a really good plan.......I'm sure your dad would have wanted you to keep the home in the family. when you get your work space set up.....you'll have to shoot a couple pictures of it. have a good move, my friend :D
User avatar
Sjors55
Chief Petty Officer
Chief Petty Officer
Post by Sjors55 » Thu May 10, 2012 2:34 pm
Hi Bob,
I found out that you have an other build.....
It looks great and clean planking.
I just told Anja that I do the same as you.
First planking from the top to the middle and then from the keel to the middle :D
I know that some are only goes from the top to the bottom.
Do you know if that has a reason?
Or is it just the way that you like.
Sjors
Whatever you do will be insignificant, but it is very important that you do it.
(Mahatma Gandhi)
Current build:
Le Mirage by Corel (1:75)
Current build: San Ildefonso by OcCre (1:70)
http://www.shipsofscale.com/phpBB3/view ... f=52&t=279
popeye
Contact:
Post by popeye » Thu May 10, 2012 2:47 pm
believe it or not....planking from the keel is the preferred method. I have never known the origin of planking from the bulwarks down......that's the way I learned to do it. when I planked the Gothenborg....I planked to the whales, and then up from the keel......seems to be the preferred method for these period ships. in any case....it's best left to the modeler to see what suits them best,.
Post Reply
