Build Log OcCre Montanes
Moderators: Aussie048, zoly99sask
Post Reply
User avatar
jct
Petty Officer First Class
Re: Build Log OcCre Montanes
Post by jct » Fri Jun 27, 2014 3:18 pm
Charles...the glazing does look good...very similar to the micro sol product I referenced, that is a good idea for the lanterns, your nephew is a very sharp lad. looking good
J
Current build -
In the queue -
Agilis, Steingraeber
HMB Endeavour, Corel
Harriot Lane, Model Shipways
Semi complete-
USS Niagara
Completed builds-
Half Moon, Corel
USN Picket Boat #1
User avatar
CharlesEdward
Petty Officer Second Class
Post by CharlesEdward » Sat Jun 28, 2014 9:55 am
I wonder if I could just paint the glazing red instead of using the red paper? I have been afraid to try it, since it seems so fragile and I can just imagine my sharp paint brush going right through the glazing.
JohnK aka Charles Edward
Current builds: Montanes, Albatross; Sao Miguel; Albatross; Wappen von Hamberg; Royal William.
Completed kits: Santa Maria; USS Dallas, Scottish Maid; Half Moon; Golden Hind, Yacht Mary; HMS Sharke.
User avatar
CharlesEdward
Post by CharlesEdward » Sun Jun 29, 2014 1:14 am
I spent today finishing the starboard bow detail. Due to some misalignment problems, the parts shown are not quite as the instructions show. I had to make a little modification for the effect would be there and the two rigging holes and gammoning slot would still be usable when it is time to rig the model.
The mountain man figurehead is not cemented to the prow yet, I used it to position the lower brass wire decoration. The instructions stated to install the wood pieces than paint them, but I decided to paint them first and then cement them in place. The brass wire is 1.5 mm in diameter and I found that it isn't easy bending brass wire and then using CY glue to attach it to the wood. The wood supports are painted black and the decoration are painted gold.
I found that cementing one end first, very carefully using what clamps I could to hold the dry wire in place while the cemented wire sets helps with slight bending corrections of wire. Although the upper brass decoration set almost exactly in 15 to 30 seconds, the lower brass decoration did NOT want to set and it took a couple of hours to get that wire installed. Both are not perfect of coarse, but don't look too bad.
A good view of my work today. Notice the top decoration ends in a shepherds' hook shape while the bottom just ends at the figurehead's feet.
Montanes_Jun_28 011.JPG (103 KiB) Viewed 2374 times
A close up of the shepherds' hook adornment.
Montanes_Jun_28 003.JPG (79.99 KiB) Viewed 2374 times
The lower decoration in a closer shot.
Montanes_Jun_28 004.JPG (104.07 KiB) Viewed 2374 times
popeye
Master Chief Petty Officer
Contact:
Post by popeye » Mon Jun 30, 2014 7:34 am
I use the Testor's window maker and cement. it's good for cementing clear parts on plastic models too. it can be painted....I've done it ;)
looking very good Charles........just need to correct the alignment on the port side grating.....and you'll be in business! :)
User avatar
CharlesEdward
Post by CharlesEdward » Sun Jul 06, 2014 12:33 pm
It has been awhile since I posted an update, but I have been working pretty steadily on the kit as you will see.
I installed the ships boat supports and affixed the main stern gallery to the stern supports. The port and starboard stern side gallery bases / supports have also been installed.
I noted that I had to sand / grind / remove a portion of the main wale directly under the side stern galleries in order to better fit the nicely molded metal piece that has to go under there. The series of photos show the dry fitted boat on its supports.
The ships boat support ready for the laying on of the ships boat.
Montanes_Jul_4 001.JPG (150.18 KiB) Viewed 2312 times
Another angle of the same boat supports. You can see the brass tie rods which will be used to secure boat to.
Montanes_Jul_4 002.JPG (135.37 KiB) Viewed 2312 times
The ships boat test fitted onto its supports.
Montanes_Jul_4 003.JPG (121.02 KiB) Viewed 2312 times
The main gallery affixed to the stern supports. I did paint the glaze behind a flat black at the center window.
Montanes_Jul_4 006.JPG (102.04 KiB) Viewed 2312 times
The starboard stern gallery bases.
Montanes_Jul_4 010.JPG (81.69 KiB) Viewed 2312 times
I found that I would have to grind, sand or otherwise remove this portion of the main wale to better fit the lower metal pieces.
Montanes_Jul_4 012 Comments.jpg (92.12 KiB) Viewed 2312 times
User avatar
CharlesEdward
Post by CharlesEdward » Sun Jul 06, 2014 12:37 pm
A short additional update on the finished quarterdeck stern lockers and chests. The photos show the dry fitted pieces not yet cemented.
The stern lockers and chests, dry fitted into position.
Montanes_Jul_4 007.JPG (90.28 KiB) Viewed 2312 times
Looking starboard stern quarter.
Montanes_Jul_4 008.JPG (100.8 KiB) Viewed 2312 times
The port stern quarter.
Montanes_Jul_4 009.JPG (74.31 KiB) Viewed 2312 times
User avatar
GaryM
Senoir Chief Petty Officer
Post by GaryM » Sun Jul 06, 2014 3:12 pm
Interesting kit. I have never seen chest and lockers used in this area before. Each country had its own unique little twists.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
popeye
Contact:
Post by popeye » Tue Jul 08, 2014 8:08 am
nice bit of progress Charles....the ship's boat looks very good! :)
windsurfmt
Post by windsurfmt » Sun Feb 15, 2015 12:52 pm
Hi all,
Here are a few pics of my progress....
20150215_093450 copy.jpg (179.97 KiB) Viewed 1633 times
Post Reply
