Build Log OcCre Montanes
User avatar
CharlesEdward
Petty Officer Second Class
Postby CharlesEdward » Sat Apr 21, 2012 9:16 am
This is a 1:70 scale model but even at that the model will measure 49" in length by 35" in height and about 19" wide when finished. The OcCre kit quality was excellent as the false keel and all 15 or 16 bulkheads fitted perfectly with just very limited sanding of bumps where the pieces were cut out of the laser cut wood stock. I finished assembling the entire carcass or hull in about two days.
The carcass looks good, all frames have fit perpendicular to the false keel with a tad flexibility to enable a proper fitting of the planked decks, part #27 and #32. In fact the support beam, part #15, going through the bulkheads is still not glued yet per the instructions.
The assembled bulkheads and false keel shown from the stern looking towards the bow.
The assembled bulkheads and false keel shown from the bow looking toward the stern.
An overhead shot of the assembled carcuss, ready for deck fitting.
JohnK aka Charles Edward
Current builds: Montanes, Albatross; Sao Miguel; Albatross; Wappen von Hamberg; Royal William.
Completed kits: Santa Maria; USS Dallas, Scottish Maid; Half Moon; Golden Hind, Yacht Mary; HMS Sharke.
User avatar
CharlesEdward
Re: Build Log OcCre Montanes
Postby CharlesEdward » Sat Apr 21, 2012 9:47 am
Started planking the two halves of the lower deck, part #27 with parts #28, 1 x 3mm. Darkened the edges of the planking strips #28 with a marking pen, too much bleeding, but the pencil is just not working as i like, I eventually used a combination of both dark pencel and marking pen to simulate the chalking. The pictures here show a dry fit of both halves of the lower deck before I had completed the planking. I cut the deck planking into ten to twelve foot scale lengths, which is about 40 - 45 mm in actual length.
Dry fitting of lower deck halves in carcass. You can see that I am doing a four strake plank offset here.
Another picture of the dry fit of the lower deck pieces before planking was completed.
Last edited by CharlesEdward on Sat Apr 21, 2012 10:24 am, edited 1 time in total.
User avatar
CharlesEdward
Postby CharlesEdward » Sat Apr 21, 2012 9:58 am
After attaching the lower gun decks in place and allowing the glue to dry I attached the upper deck cross beams in place which will support the upper gun deck when deck planking is completed.
The stern gallery assembly.
A view from the stern looking toward the bow of the upper deck support beams installed.
The upper deck cross beams all ready for the laying of the upper deck.
Last edited by CharlesEdward on Sat Apr 21, 2012 11:40 am, edited 1 time in total.
User avatar
CharlesEdward
Postby CharlesEdward » Sat Apr 21, 2012 10:16 am
I continued with planking of the upper gun deck. When completed I assembled the two halves of the upper gun deck to the carcass as shown below. My next post will show some close up shots of the assembled kit.
The upper gun deck in place.
Planking the upper deck trying to match the four strake offset around the deck openings as best as possible.
The planking operation of the upper gun deck.
Last edited by CharlesEdward on Sat Apr 21, 2012 10:25 am, edited 1 time in total.
User avatar
CharlesEdward
Postby CharlesEdward » Sat Apr 21, 2012 10:22 am
As promised some close up pictures of the assembled lower and upper gun decks as well as some bow and stern support filler blocks that were added per instructions. The columns were 3mm dowels cut to size.
Midships view.
Aft of the midship view. You can see the offset that I tried to simulate with the deck planking here.
A different angle of the midship area.
User avatar
GaryM
Senoir Chief Petty Officer
Postby GaryM » Sat Apr 21, 2012 10:32 am
Nice start.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
GaryM
This looks like a good quality kit. However, I like double planked ships since that is how the real ones were done. On warships, the cannon areas were triple planked which is what I have added to the Le Soleil Royal that I am working on. Deck planking was usually 20 to 24 foot lengths. Good luck.
Happy modeling,
Gary Maple
User avatar
CharlesEdward
Postby CharlesEdward » Sat Apr 21, 2012 10:37 am
After the upper and lower gun decks were in place the instructions called for the bow and stern filler pieces to be glued into place. You can see them here plus an overhead view of the model before I started to add the gun deck bulwarks that are required prior to starting the hull planking.
An overhead view of the entire model before hull work commenced.
View of the stern gallery supports.
Looking at the stern gallery assembly.
Looking at the bow filler blocks.
User avatar
CharlesEdward
Postby CharlesEdward » Sat Apr 21, 2012 11:07 am
The kit included port and starboard pre-cut upper and lower gun bulwarks in addition to the main deck bulwark which starts to hint at the entire look of the model. But before that you have to make the dummy gun mounts which will be used for the dummy guns, of course. There are quite a few of them. The instructions called for just using the plywood cut to size to fit between the bulkheads but I determined that a base as shown in the second picture would make the dummy mounts easier to glue to the decks at a almost 90 degree angle to the decks. The first picture below shows the model before commencing hull operations.
Dummy gun mounts dry fitted already painted a flat black in preparation of installation unto the gun decks.
The starboard bow dummy gun mounts dry fitted.
Various parts #39 cut to fit between bulkheads on the lower gun deck. Look close and you can see my base that I installed on each piece.
My device to help "stand up" the dummy gun mounts.
I tried to use less wood stock so I did not attach the bases the full length of each dummy mount.
The assembled model prior to commencing the bulwark and hull planking operations.
User avatar
CharlesEdward
Postby CharlesEdward » Sat Apr 21, 2012 11:21 am
The precut upper and lower gun deck bulwark pieces are shown here assembled on the port side of the Montanes. The uupper bulwark is where the dummy gun mounts shown in the previous post are behind. The lower bulwark uses a 14 x 14 mm piece of plywood painted black glued to the reverse side of each gun port. As you notice there really isn't a deck behind the lowest gun bulwark so these false backs are needed to affix the dummy guns to at a later date.
A closer look at the bulwarks.
The two gun deck bulwarks assembled.
Who is online
Users browsing this forum: No registered users and 5 guests
