ZHL Misticque
Moderators: Aussie048, zoly99sask
Post Reply
User avatar
Donnie
Senoir Chief Petty Officer
Contact:
Re: ZHL Misticque
Post by Donnie » Sun Oct 29, 2017 10:53 pm
Wow !! Very nice. Things look lined up really well.
Donnie
Current Build: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
"War Ships are safe at harbor, but that is not what they were made for"
User avatar
JohnSilver
Seaman
Seaman
Re: ZHL Misticque
Post by JohnSilver » Mon Oct 30, 2017 4:21 pm
Hi Geoff and Donnie
Thank you for your comments.
I did not take the keel apart, I put a block of wood half way down and put a clamp on it then went to the bow end and clamped that, this bent the bow part about 25mm and left it for about 4 days.
I think it worked as it is only about less than half a millimetre out, I am hoping that when the lower deck goes on it will pull this into line.
John.
User avatar
Donnie
Contact:
Re: ZHL Misticque
Post by Donnie » Thu Nov 02, 2017 9:06 pm
John,
that should work fine. I have had to do things like this before. I thought I would never get my San Felipe Keel straight. Even using the admirals iron !!
Donnie
Donnie
User avatar
JohnSilver
Seaman
Seaman
Re: ZHL Misticque
Post by JohnSilver » Thu Nov 02, 2017 10:04 pm
Hi Donnie
I think it was my fault I just glued it and left it on the table, should have put something on top.
Next it is sanding some frames but the admiral has to go out first ha ha.
John.
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Re: ZHL Misticque
Post by Aussie048 » Fri Nov 03, 2017 5:56 pm
Hi John
It sounds like you need to give the Admiral a good excuse to go out, I am sure you will think of something.
Cheers
Geoff
Aussie048
Current Build Link:-
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
User avatar
janos
Petty Officer Second Class
Re: ZHL Misticque
Post by janos » Fri Nov 03, 2017 8:04 pm
John
it will be a beautiful model!
A bit too late but I used isopropyl alcohol to un-glue parts (previously glued with Triton glue) and I am happy with the result. It is available at Bunnings.
Janos
User avatar
JohnSilver
Seaman
Seaman
Re: ZHL Misticque
Post by JohnSilver » Mon Dec 04, 2017 9:47 pm
Hi all
I know I am going a bit ahead of myself but I find it hard to find wood for the base.
I emailed a timber yard and said I was looking for a slab of Cherry for a baseboard.
They had the size I wanted 800mm x 200mm x 25mm but it is rough sawn, so as I have a thickness sander I will sand it down with that.
Ordered it Thursday arrived yesterday (Monday).
It cost $46 + P and P $40.
John.
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Re: ZHL Misticque
Post by Aussie048 » Tue Dec 05, 2017 12:25 am
Hi John
It is not to early to think about the base board as you will need a way of screwing you Mystique to the base board.
My thicknesser will only handle 80mm wide which in most cases will be wide enough.
Cheers
Geoff
Aussie048
On Hold Builds:-
Santa Maria
Member
User avatar
Brian077
Petty Officer First Class
Re: ZHL Misticque
Post by Brian077 » Tue Dec 05, 2017 12:59 am
hi John,
I ordered a beautiful solid cherry baseboard with routed edges of the same dimensions as you specified from Max at ZHL models and it was cheaper than what you paid.
cheers Brian.
User avatar
JohnSilver
Seaman
Seaman
Re: ZHL Misticque
Post by JohnSilver » Tue Dec 05, 2017 9:16 pm
hi John,
cheers Brian.
Now you tell me.
John
Post Reply
