Armed Virginia Sloop 1768 - Model Shipways - scale 1:48
Moderators: zoly99sask, Aussie048
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Post by zoly99sask » Mon Aug 14, 2017 12:44 pm
I started to build the Armed Virginia Sloop in 2007,here are the pictures about the build,bulkheads installed,false deck glued in and planking has been started.
IMG_0347 (800x600).jpg (216.28 KiB) Viewed 35 times
IMG_0349 (800x600).jpg (221.2 KiB) Viewed 35 times
IMG_0350 (800x600).jpg (246.51 KiB) Viewed 35 times
IMG_0351 (800x600).jpg (242.89 KiB) Viewed 35 times
IMG_0353 (800x600).jpg (233.54 KiB) Viewed 35 times
IMG_0355 (800x600).jpg (235.24 KiB) Viewed 35 times
IMG_0356 (800x600).jpg (212.99 KiB) Viewed 35 times
IMG_0358 (800x600).jpg (236.74 KiB) Viewed 35 times
donfarr
Petty Officer First Class
Re: Armed Virginia Sloop 1768 - Model Shipways - scale 1:48
Post by donfarr » Mon Aug 14, 2017 1:41 pm
Will follow this one with interest Zoly as I have this kit and will build it once I catch up with other build hopefully by the first of next year. Don
donfarr
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Post by zoly99sask » Mon Aug 14, 2017 1:49 pm
After 2007 stopped working on the ship until 2011 due to several moving and lack of time.Here are the pictures from 2011 with the first planking.
IMG_1006 (Copy).JPG (160.05 KiB) Viewed 35 times
IMG_1007 (Copy).JPG (188.19 KiB) Viewed 35 times
IMG_1008 (Copy).JPG (139.48 KiB) Viewed 35 times
IMG_1010 (Copy).JPG (116.26 KiB) Viewed 35 times
IMG_1011 (Copy).JPG (139.53 KiB) Viewed 35 times
IMG_1019 (Copy).JPG (133.82 KiB) Viewed 35 times
IMG_3543 (Copy).JPG (106.06 KiB) Viewed 35 times
IMG_3544 (Copy).JPG (90.93 KiB) Viewed 35 times
IMG_3545 (Copy).JPG (81.43 KiB) Viewed 35 times
IMG_3546 (Copy).JPG (81.51 KiB) Viewed 35 times
IMG_3550 (Copy).JPG (104.04 KiB) Viewed 35 times
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Post by zoly99sask » Mon Aug 14, 2017 1:50 pm
donfarr wrote:Will follow this one with interest Zoly as I have this kit and will build it once I catch up with other build hopefully by the first of next year. Don
Thank you very much Don for visiting my build log.
User avatar
DenisR
Petty Officer Second Class
Post by DenisR » Thu Aug 17, 2017 7:19 pm
Hi Zoltan
Very nice build, I also will follow this one.
Denis.
User avatar
Brian077
Post by Brian077 » Thu Aug 17, 2017 7:37 pm
me too. Wonderful model Zoly.
neptune
Contact:
Post by neptune » Fri Aug 18, 2017 3:15 am
You can add me to the list as well Zoly,
best regards John.
User avatar
Mike41
Post by Mike41 » Fri Aug 18, 2017 3:31 am
Hi Zoltan,
Great start on the build if you have room for one more I will pull up a chair.
Mike
Mike41
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Post by zoly99sask » Fri Aug 18, 2017 9:00 am
Thank you very much guys for joining the journey!!
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Post by zoly99sask » Sat Aug 19, 2017 8:16 am
In 2011 I stopped working on the ship again,up until February 2015 and working on since,so I finished the first planking with a good sanding and started working on the scuppers ,somehow I missed them ,then I drilled the sweep ports.
Scuppers (2) (Copy).JPG (202.44 KiB) Viewed 32 times
Scuppers (3) (Copy).JPG (147.71 KiB) Viewed 32 times
Scuppers (4) (Copy).JPG (140.74 KiB) Viewed 32 times
Scuppers (9) (Copy).JPG (180.18 KiB) Viewed 32 times
Scuppers (11) (Copy).JPG (150.2 KiB) Viewed 32 times
Scuppers and sweep ports (12) (800x533)_000.jpg (193.96 KiB) Viewed 32 times
Scuppers and sweep ports (16) (800x533)_000.jpg (193.87 KiB) Viewed 32 times
Scuppers and sweep ports (17) (800x533)_000.jpg (163.02 KiB) Viewed 32 times
Scuppers and sweep ports (18) (800x533)_000.jpg (201.86 KiB) Viewed 32 times
Scuppers and sweep ports (21) (800x533)_000.jpg (188.81 KiB) Viewed 32 times
Post Reply
