Freidrich Wilhelm Zu Perde 1/48 scale by Euro Model
Moderators: zoly99sask, Aussie048
neptune
Petty Officer First Class
Contact:
Re: Freidrich Wilhelm Zu Perde 1/48 scale by Euro Model
Post by neptune » Sun Aug 13, 2017 10:35 pm
The lighting I had originally installed comprised of different globes etc, so I ripped it all out and installed some very small leds, I had to make several cuts in the wale planks in order to extract and reinstall the new leds.
These leds were again xmas lights that I bought from Cheap as Chips store, again they came with a resistor.
I also ripped off the partial planking that was on the port lower hull so I could remove and replace the lighting.
New lights and wiring being installed, new planking will hide all the wires etc.
These next five pics show the new lighting in place and lit up. The camera seems to pick up and magnify the globes, the lighting has a more subdued effect when viewing in normal conditions.
neptune
Contact:
Post by neptune » Sun Aug 13, 2017 10:43 pm
Some of the cannon for the upper deck
Out baord view of upper cannons in plce
View of the after most five cannon
neptune
Contact:
Post by neptune » Sun Aug 13, 2017 10:52 pm
I had cut the deck beams years ago when I had last worked on the model
View along the deck with the cannon breeching rope in plce
Focsle beams in place
I just realised in time that I had to rig the Jeer blocks to the knights heads, fore one was not too bad, but the main was a bit fiddly, see next pic.
Main jeers block rigged, i'm holding them up with some string just to take the photo's.
neptune
Contact:
Post by neptune » Sun Aug 13, 2017 11:10 pm
Next up was the tiller arm to be rigged to the whip staff, I managed to drill a small hole in the end for the small metal connecting piece to go in.
Close up.
Connecting piece in place
Very basic whip staff with a small eyebolt to connect to the tiller arm.
Whip staff and arm connected.
Hole that the whip staff passes through
and the finishing touch to the hole.
neptune
Contact:
Post by neptune » Sun Aug 13, 2017 11:24 pm
The captains four poster bed I twisted some copper wire together to make the posts and used some fancy little bitts that women muse to make jewellry for the top and bottom of the posts.
All four made up the extra long piece on each end will glue in a hole drilled in the deck.
One post close up.
The basic bed
Approx where it will go
another view
User avatar
Peglegreg
Petty Officer Third Class
Post by Peglegreg » Wed Sep 13, 2017 11:43 pm
G'day John
Just brilliant my friend. How do you get time to do all the work on not only this model, but the other 2 which I have found.
I'll will be watching for more updated mate.
Havagooday tomorrow.
:music-rockout:
Greg
The only limitations that are on you, are the ones that you put on yourself!
neptune
Contact:
Post by neptune » Sun Oct 08, 2017 7:50 am
G'day all, thats all the photo's reposted on this build log,
best regards John.
Post Reply
