ZHL Royal Caroline Kit, scale 1/30
Moderators: Aussie048, zoly99sask
Post Reply
User avatar
Peglegreg
Petty Officer Third Class
Re: ZHL Royal Caroline Kit, scale 1/30
Post by Peglegreg » Sat Aug 26, 2017 11:23 pm
I also have every faith in your ability to get it right.
Just wanted to put my noise in, just in case mate. ;-)
Happymodelling
Greg
The only limitations that are on you, are the ones that you put on yourself!
neptune
Petty Officer First Class
Contact:
Post by neptune » Sat Aug 26, 2017 11:29 pm
No worries mate, I was just taking the Michael out of myself, :o :o :o
neptune
Contact:
Post by neptune » Sun Aug 27, 2017 12:51 am
Well Greg had me thinking and I just had to fix the lower rails and see if everything went together OK,
The lower glued in place
The Princess trimmed and just sitting on the stem
and with the bowsprit sitting in place, looks like ev thing will be OK.
User avatar
Peglegreg
Post by Peglegreg » Mon Aug 28, 2017 5:19 am
G'day John
Looks great........No need to be concerned!
:text-imsorry:
I'm sorry for giving you the anxiety and worries!
You are doing a beautiful job and I promise not to doubt you again.
:handgestures-thumbup:
Keep up your standard work and everything will be apples.
:roll:
Happymodelling
Greg
neptune
Contact:
Post by neptune » Mon Aug 28, 2017 7:38 am
Shellby right mate, no worries, :angry-cussingblack: :angry-banghead: :banana-rock:
neptune
Contact:
Post by neptune » Mon Aug 28, 2017 7:51 am
G'day John
:text-imsorry:
:roll:
Happymodelling
Greg
no worries Greg, if you ever see something that you think is not right or might be a problem along the line, let me know, I would rather check it now than find out later on,
best regards John.
neptune
Contact:
Post by neptune » Mon Aug 28, 2017 7:54 am
Thats the hawse pieces attached and also the back suport board for the Cherubs that hold the crown over the Princess head
Another view. I will not attach the figure head till later on so as not to damage it whilst turning the model around when working on it.
neptune
Contact:
Post by neptune » Mon Aug 28, 2017 8:11 am
In my haste to to build the kit I made a mistake and glued the outboard end of the cat heads in place before cutting the slots for the sheaves
So I had to cut them off, then using a .5mm blade I proceeded to cut the slots, I marked where I wanted to start and then I cut a slot in each, then I moved the fence a little and cut some more and I continued till the slots were as wide as I needed, then I finished them with a small file,
I could have used a wider blade but did'nt want them splitting out,
After finishing with the file
With the sheaves temporarily in place.
also due to the size of the sheaves I had to move the hole for the sheave wire to go through, or I would'nt have been able to get the ropes up over the sheaves.
another view
Showing the lions face on the front.
Approx where the cat head will sit. I will blacken the sheaves and varnish the heads before final assembly.
User avatar
GaryM
Senoir Chief Petty Officer
Post by GaryM » Mon Aug 28, 2017 9:44 am
The detail of this ship just keeps coming. What a neat project.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
User avatar
Peglegreg
Post by Peglegreg » Mon Aug 28, 2017 4:35 pm
G'day John
Another brilliant job or can I say 'save'.
:text-lol:
I would assume that if you didn't havta cut the lion head off , the axel for the pulley would be in the correct place.
OK mate, if I can see a possible boo boo from you, I will speak out. But I doubt it will ever happen!
:banana-rock:
Looking forward for your next update.
Havagooday
Greg
Post Reply
