Halifax Build Log: Lumberyard
Moderators: Aussie048, zoly99sask
Post Reply
donfarr
Petty Officer First Class
Re: Halifax Build Log: Lumberyard
Post by donfarr » Tue Aug 22, 2017 1:24 pm
Happy you are back Dave, a couple of questions for you, you SAID THAT FOR WHATEVER LEGAL REASONS THAT THE PLANS WERE DISTORTED, can I still take the mesurments off the plans, when I first put together theKEEL ASSEMBLY IT WAS QUITE A BIT OFF FROM THE PLANS, what do I do,....also I elected to put the KEEL ASSEMBLY IN PLACE WIT FRAMES No. A AND V(first and last whole frame) and CLAMPED THE FRAMES TO THE KEEL NOTCHES,.....then adjusted the frames to the jig, mostly pulled up from the bottom of the jig, this would not matter as the frames eventually get cut off from the jig itself,....but would it not change the mesurments to underside of CAP RAIL AND THE WALE ITSELF,,,,,,pictures forth comming, NEED YOUR HELP ON THIS AND THE CANT FRAME BEVELING,...I JUST CAN NOT SEEM TO GET THAT THROUGH MY ANCIENT MIND, looking forward to your help. Don
donfarr
Post by donfarr » Wed Aug 23, 2017 3:13 pm
Hi everyone, showing progress to date, all whole frames complete in place, have quite a bit of fairing to do yet, and stern half frames, and stem cant frames to install
User avatar
admin
Site Admin
Contact:
Post by admin » Wed Aug 23, 2017 9:01 pm
didit,
You might want to go back and re upload some images that I noticed were missing. They are on the post that has these:
Donnie Driskell
Ships of Scale ©2017
Madison, MS
USA
Owner / Operator / Administrator
admin@shipsofscale.com
Thank you again for your membership and interest.
You do make a difference in the community of Ship Builders !
donfarr
Post by donfarr » Fri Aug 25, 2017 11:20 am
OK starting to post pictures
Showing a mistake and how I corected it,this is Frame No. 9, showing it wrong, takeing it apart by using nail polish remover with 100 per cent acetone, using cotton swab on the joints and an ezato blade got it apart with no damage re-did the frame corectly, this is wgat happens when you are to tired to do modeling work
donfarr
Post by donfarr » Fri Aug 25, 2017 11:50 am
so now I know it is working again, here are the posts showing progress and questions
cant frames No. 5, 6, and 7 dry fitted, is this correct once I get it into rabbit, do I nedd any beveling yet
stern off center, will fix it when installing the half frames by pushing them in
side view wit half frame No. W dry fitted
whole frames attached to keel
whole frames installed to keel and jig
donfarr
Post by donfarr » Mon Aug 28, 2017 11:03 am
Where are the pictures for these items how do I get them up. DON
donfarr
Post by donfarr » Mon Aug 28, 2017 11:07 am
I AM REFERING TO didits posts(FOR 8/22) need to know how to open the pictures on these items. DON
User avatar
Aussie048
Post by Aussie048 » Mon Aug 28, 2017 10:30 pm
Hi Don
We need Didit to fix those as we do not have the photos. If you or Didit has the photos or you emailed me with them I could fix the posts.
Cheers
Geoff
Current Build Link:-
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
neptune
Contact:
Post by neptune » Wed Aug 30, 2017 6:17 am
G'day Don, finally getting a bit of time to catch up on some builds, this is a beautiful little Schooner, I just love the framing you are doing, will you be leaving the hull open, ( no planks ) below the wales,
best regards John.
didit
Seaman
Seaman
Post by didit » Wed Aug 30, 2017 8:08 am
I just looked back and I can see all the photos in the 8/22 post
I am away from home right now gone on vacation for the next 10 days
dave
Post Reply
