Mantua Sovereign of the Seas 1:78 bashed to death kit from Janos
Moderators: zoly99sask, Aussie048
User avatar
Donnie
Master Chief Petty Officer
Contact:
Re: Mantua Sovereign of the Seas 1:78 bashed to death kit from Janos
Post by Donnie » Fri Mar 17, 2017 10:05 am
I have to admire anyone that can bash a kit. This is beyond my capabilities and knowledge. I am sure that I am will learn a lot by watching this come to life.
Donnie
Donnie
Current Build: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
"War Ships are safe at harbor, but that is not what they were made for"
User avatar
janos
Petty Officer Second Class
Post by janos » Thu Mar 23, 2017 6:59 am
First planking is now nearly finished. Main deck planking has been installed (not waterway, king plank) - still to be scraped.
I probably have to use more kit parts than I previously thought - but only as 'false' pieces, ie. they will be 'really' planked.
Janos
DSC_3844 s.jpg (109.79 KiB) Viewed 79 times
DSC_3845 s.jpg (110.37 KiB) Viewed 79 times
DSC_3852 s.jpg (105.89 KiB) Viewed 79 times
DSC_3851 s.jpg (98.45 KiB) Viewed 79 times
User avatar
janos
Post by janos » Mon Mar 27, 2017 6:07 am
The main deck will be over-planked as I did not like the first one and I was also assuming that the material I have will not be enough. So start again.
During the Maritime Museum volunteer hours I have to work on something which is not too big so I can carry it (unlike the SoS hull) so I started working on the figure head. At the moment it is being roughed out.
Janos
DSC_3854 s.jpg (83.96 KiB) Viewed 78 times
DSC_3855 s.jpg (81.94 KiB) Viewed 78 times
User avatar
Canoe21
Petty Officer First Class
Contact:
Post by Canoe21 » Sat Apr 15, 2017 6:00 am
Hello Janos
Great job you are doing on your hull planking, I also like very much your figurehead carving, such skills you possess. I am almost tempted to give that kind of carving a try, ENJOY.
Regards Canoe21 { Lawrence }
canoe21 { Lawrence }
PRESENT BUILD - viewtopic.php?f=59&t=1221 - GOLDEN HIND< Harold A. Underhill build plans, scale 1:60
Completed Build viewtopic.php?f=59&t=1172 HMS Bounty, scratch build, scale 1:60, using Amati build plans
User avatar
janos
Post by janos » Tue Apr 18, 2017 3:44 am
Some update about this slow build. The decks have now been re-planked. Gunport-frames made of square tubes, glued into position and thinned to the thickness of the primary planking. I also marked the frame positions (every second) on the hull to be able to create the right plank-pattern. Then I started outside planking. The material above the uppermost wale will be Swiss Pear and Pear Wood below it. The planking will consist of planks, the length of which is to scale (wales are in full length though). I am going to continue with the Swiss Pear planking up to the point that I can start carving and from there on these two things will happen concurrently. The bow section will be covered by 'strips' as opposed to the kit's deck planking. Some parts are already manufactured for this (as are gratings) and I will do the bow as soon as I reach its top with the planking.
Janos
DSC_3860 s.jpg (104.67 KiB) Viewed 77 times
DSC_3861 s.jpg (115.28 KiB) Viewed 77 times
DSC_3863 s.jpg (107.73 KiB) Viewed 77 times
DSC_3865 s.jpg (99.1 KiB) Viewed 77 times
DSC_3866 s.jpg (102.88 KiB) Viewed 77 times
User avatar
GemmaJF
Post by GemmaJF » Tue Apr 18, 2017 7:13 am
I'm steeling your gun port frame idea! Been thinking how to do it, expensive farmed out laser cutting of walnut, make them up from thin strip, this is a much better idea. Thanks for sharing. :handgestures-thumbup:
Current Build: ZHL Black Pearl 1:50
Next Up: Billing Boats Bounty 1:50
Researching for POB scratch build : HMS Ferret 1:48 (1711)
Projects: Arduino Lighting Project
User avatar
Donnie
Contact:
Post by Donnie » Fri Apr 21, 2017 11:32 am
Superb techniques. I assume that the pencil vertical lines are your markings for the butt joints for the final planking?
Donnie
Donnie
NMBROOK
Post by NMBROOK » Mon Apr 24, 2017 3:51 pm
Hi Janos
Excellent to see you are building the Sovereign.You certainly have your work cut out with the many carvings.As for the figurehead being a small part mmm it has to be one of the most complex carvings around probably only matched by the figurehead of the Royal William.
I do wonder though if your log belongs in the scratch section in view of the extensive modifications,that is where my build resides?
Kind Regards
Nigel
User avatar
janos
Post by janos » Tue May 02, 2017 7:20 am
Thanks, Gemma, Donnie & Nigel!
SoS is proceeding slowly The hull planking above the top wale is Swiss Pear (just partially sanded, hence the big colour variation) and below the top wale is Pear Wood. The inside planking is Bloodwood. Now the model is placed on my trusty mobile cradle upside down and after the banding is marked, I am proceeding with the Pear Wood planking.
Donnie: yes, the pencil marks are for the butt joints, every second frame is marked.
Nigel: I am not going to use anything else from the kit so the build might go to the scratch buildings, but because I started with the kit, it is not a 100% scratch build. So it is up to Donnie to finalize where he thinks it is placed at the best.
Janos
DSC_3880 s.jpg (101.55 KiB) Viewed 76 times
DSC_3881 s.jpg (134.42 KiB) Viewed 76 times
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Tue May 02, 2017 7:38 am
Janos
I admire your build of the Sovereign of the sea, just beautiful work.
Cheers
Geoff
Aussie048
Current Build Link:-
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
Post Reply
