Build Log: Panart Armed Pinnace
Graham
Petty Officer Second Class
Re: Build Log: Panart Armed Pinnace
Postby Graham » Fri Mar 03, 2017 3:09 pm
Thanks guys, I appreciate your comments.
So, on with the second layer of three. Since this layer will never be seen I could slap the planks on, all pretty rough, use a lot of filler and have it done in a day. However, any planking experience is good experience and I do need to get better at some aspects - tapering any stealers, bending etc. And I have been doing some reading - always a dangerous thing to do. I would like to add a bit of realism to the outer layer and will do a butt shift system, which is how the planks have a stepped appearance rather like bricks in a wall - I know that is a massive over-simplification, but you get the idea. I looked at 3 butt shifts and 4 butt shifts. In the end I opted for something simpler on this layer and this is 'Graham's butt shift system' with a simple overlap one quarter plank length shift. I have opted for a plank length of 8 inches which gives a scale length of 12 ft. That might be wrong, I don't know, but I like the look.
Learning point: It is useful now and again to lay on and fix a full uncut plank, but marked via a wedge shaped cut at the appropriate plank length chosen - they'll never know. This isn't so much cheating as putting a complete and uncut plank length in place in order to get back a straight edge to work to and keep the edge fits tight - I fear a buildup of tolerances of any edge gaps which might result in some pretty funky shaped in-fill pieces later.
Ever onward, we'll see how this ends up.
Graham
Postby Graham » Fri Mar 03, 2017 3:46 pm
It seems to be going OK. I can not pin to the frames for reasons previously explained, so the curve and twist of the planks takes some time (I use a heated bender) in order for them to lay flat and not spring. The problem comes in that as I work towards the keel I am now beyond the reach of the clamps I have and although I use CA it is pretty boring holding each plank in place while the glue sets. The solution I came up with was to bend some planks, pin them to the underside of the keel, then clamp them such that they press on the plank being glued. As I move up the hull they can be re-shaped or packers used in order that the contact point is over the plank being glued in place, and they can be swung over to work on the opposite side of the hull when necessary.
It seems to work pretty well, so I thought I'd share it with you.
Graham
Postby Graham » Sat Mar 25, 2017 10:42 am
Further progress on the second layer of planking.
Second layer completed...
... and sanded
Not really anything to report to you on special techniques or anything, it's just a case of a steady plod and careful measuring. As my Dad used to say 'Measure twice, cut once'; wise words, indeed.
User avatar
mtbediz
Seaman
Seaman
Postby mtbediz » Mon Apr 03, 2017 5:52 am
Graham wrote:It seems to be going OK. I can not pin to the frames for reasons previously explained, so the curve and twist of the planks takes some time (I use a heated bender) in order for them to lay flat and not spring. The problem comes in that as I work towards the keel I am now beyond the reach of the clamps I have and although I use CA it is pretty boring holding each plank in place while the glue sets. The solution I came up with was to bend some planks, pin them to the underside of the keel, then clamp them such that they press on the plank being glued. As I move up the hull they can be re-shaped or packers used in order that the contact point is over the plank being glued in place, and they can be swung over to work on the opposite side of the hull when necessary.
Hi Graham,
Hull planking looks amazing. By the way, i can suggest you to use rubbers to keep planks in place while glue sets in your next build. It maybe more convenient for you. Have a great day.
Mustafa
User avatar
paulv1958
Petty Officer Third Class
Postby paulv1958 » Mon Apr 03, 2017 6:37 am
Nice job.
Already built:
Occre Albatros
AL Endeavour Longboat
AL Spanish Galleon Heritage Kit
Panart : Between Gun decks ( bashed)
Caldercraft Endeavour.
AL King of Mississippi
Corel Victory Cross Section
On shelf
AL Santa Ana ( Next Build)
Caldercraft HMS Victory
User avatar
GemmaJF
Petty Officer First Class
Postby GemmaJF » Mon Apr 03, 2017 9:08 am
Another suggestion if you want to carry-on with CA, get some kicker, apply it to the opposite surface to where you have applied the glue, will shorten the time you need to hold it considerably
https://www.amazon.co.uk/Zap-Products-K ... B000H7H4OQ
Current Build: ZHL Black Pearl 1:50
Next Up: Billing Boats Bounty 1:50
Researching for POB scratch build : HMS Ferret 1:48 (1711)
Projects: Arduino Lighting Project
Who is online
Users browsing this forum: No registered users and 6 guests
