San Felipe 1690 Build Log
arizonasun
Seaman
Seaman
Postby arizonasun » Thu Jan 12, 2017 7:32 am
So this is it the start of the San Felipe
After completing the HMS Pandora a few years ago I promised myself I would never do another period ship model as that one took me 5 years !
So here I am starting another one, and yes ive now jumped in the deep end with probably one of the hardest ships to construct, so who knows how long this one will take.
But its a hobby and theres no time limit on it, the idea is to enjoy it and its finished when its finished (well thats what I keep telling myself)
Please note from page 3 onwards the pictures are of a much higher quality.
The first stage was to make sure the hull formers are straight, and think of a way of holding the hull while it is being constructed.
arizonasun
Seaman
Seaman
Re: San Felipe 1690 Build Log
Postby arizonasun » Thu Jan 12, 2017 7:38 am
The side ribs showing the blocks that are used to accept the dummy canons, looking back now it would have been better to have made these bigger, so the tolerance was bigger when opening up the gun ports.
Start of Hull (1).JPG (39.56 KiB) Viewed 478 times
Start of Hull (4).JPG (42.96 KiB) Viewed 478 times
arizonasun
Seaman
Seaman
Postby arizonasun » Thu Jan 12, 2017 7:40 am
Showing the blocks in position again looking back it would have been better to have painted these out black before the planking was started.
Start of Hull (17).JPG (30.08 KiB) Viewed 478 times
arizonasun
Seaman
Seaman
Postby arizonasun » Thu Jan 12, 2017 7:41 am
The 3 decks glued in positioned along with the rear terrace's.
Start of Hull (8).JPG (30.69 KiB) Viewed 478 times
arizonasun
Seaman
Seaman
Postby arizonasun » Thu Jan 12, 2017 7:42 am
Another view of the decks, note the timber across the deck on the 7Th hull former was only glued slightly as this was to be removed at a later stage.
Start of Hull (17).JPG (30.08 KiB) Viewed 477 times
User avatar
Donnie
Senoir Chief Petty Officer
Contact:
Postby Donnie » Thu Jan 12, 2017 9:45 am
Thanks arizonasun for posting your work. I appreciate it. Not only me, but I am sure that others might be contemplating this build too.
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
User avatar
popeye
Master Chief Petty Officer
Contact:
Postby popeye » Thu Jan 12, 2017 1:31 pm
impressive hull frame.........she's a big girl!~
finished builds:
Nordkap 476 / Cux 87 / Gundalow
Mary Ann / Susan A. / M&M fun ship
Phylly C & Denny-Zen / AmericA
Andrea Gail
in cue:
Gothenborg
Half Moon
Boulogne Etaples
trawler Syborn
U.S.S. United States
Holiday Harbor
Titanic
arizonasun
Seaman
Seaman
Postby arizonasun » Fri Jan 13, 2017 2:00 pm
A close up of the rear terrace's showing the curvature of the decks. The two blocks between the two rear terraces are there to keep them parallel to one another, while providing more strength.
Start of Hull (19).JPG (82.53 KiB) Viewed 464 times
Start of Hull (21).JPG (88.91 KiB) Viewed 464 times
arizonasun
Seaman
Seaman
Postby arizonasun » Fri Jan 13, 2017 2:04 pm
The start of the planking always a daunting task, firstly I laid a couple of lime strips along the hull fairly straight with the decks.
Lime Planking 02.JPG (96.49 KiB) Viewed 464 times
A few more are positioned , the technique I used is to nail through an off cut of wood let the glue dry and then break the off cut of wood away the nail can then be removed easily. (You can see this on the bottom plank)
Lime Planking 06.JPG (87.48 KiB) Viewed 464 times
I alternated the planking on each side of the hull, doing 2 planks on one side then two on the other, this assured that the hull remained straight and was not pulled to one side.
I had to remember to mark the centre lines of the blocks for the dummy canons.
Lime Planking 11.JPG (92.83 KiB) Viewed 464 times
The hull had to be turned over now, I made up some blocks off wood for the hull formers to rest on and screwed it with some very small screws to stop the hull from moving around while it was being worked on.
This proved to be very successful.
Lime Planking 14.JPG (89.2 KiB) Viewed 464 times
arizonasun
Seaman
Seaman
Postby arizonasun » Fri Jan 13, 2017 2:08 pm
I decided to start planking the rear of the boat at this stage, probably because i was bored with the other planking !
Lime Planking 16.JPG (90.95 KiB) Viewed 464 times
Lime Planking 17.JPG (84.9 KiB) Viewed 464 times
A view of the front of the hull with the lime planking finished.
Lime Planking 20.JPG (82.13 KiB) Viewed 464 times
A view of the back of the hull with the lime planking finished.
Lime Planking 21.JPG (85.17 KiB) Viewed 464 times
And that was the first layer of planking finished.
Lime Planking 25.JPG (91.78 KiB) Viewed 464 times
Where the lime meets the centre of the hull I rebated the ply to accept the wood so the finished hull would be only one thickness of wood (when the walnut was applied) above the ply level.
Lime Planking 26.JPG (85.21 KiB) Viewed 464 times
Who is online
Users browsing this forum: No registered users and 6 guests
