Cutty Sark Kit bashing Del Prado
Moderators: Aussie048, zoly99sask
User avatar
BETREMIEUX
Seaman
Seaman
Post by BETREMIEUX » Mon Dec 19, 2016 3:12 pm
Hello,
I come to your forum to submit my Cutty Sark.
It is first a Del Prado kit! But it is very bad and I do everything again
With plans by GF Campbell.
Here are some photos.
I can not post one photo !!
It's a test to see if all is ok.
(I speek very bad english and i work with google.)
Daniel.
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Re: Cutty Sark Kit bashing Del Prado
Post by eric61 » Mon Dec 26, 2016 4:15 am
Hello Daniel and welcome to the forum. I will try to help you through with posting pictures, first, what is you language? second, if you look below the photo of me you will see the word "Contact", click on the three little dots and a small window will appear, click on the middle one that looks like an envelope, that will open an email that you can send to me. When I reply to your posts I will reply in both English and your language.
Is the Cutty Sark built or in a kit?
Regards
Eric
Cook's Endeavour - current,
Sovereign of the Seas - current (deAgostini)
In queue: Marina II Fishing Boat by Artesania Latina
In queue: Mayflower by Model Shipways
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Wed Dec 28, 2016 1:12 am
Bonjour Daniel, désolé pour le retard.
I f vous voulez savoir comment poster des photos suivez le lien que j'ai joint ci-dessous:
Http://www.shipsofscale.com/sosforums/v ... f=62&t=895
Si votre appareil prend ses photos à une résolution plus élevée, définissez toujours vos images à ± 900 x 600 de cette façon elles seront entre 200 et 300 Kb.
Je demanderai aussi à Donnie de déplacer votre message sur la bonne zone du forum (Build Logs from Kits - Wood)
J'ai quelques logs de construction en ce moment, le principal est le HMS Endeavor (http://www.shipsofscale.com/sosforums/v ... f=52&t=718). Je fais aussi le souterrain de la mer, Mayflower et Marina II chalutier de pêche.
J'espère que cela vous aidera, mon adresse e-mail personnelle est: e_hwall@iinet.net.au
(Il existe un trait de soulignement entre e et h (e_h)
Jusqu'à la prochaine fois.
Cordialement
Eric
Hello Daniel, sorry for the delay.
I f you want to know how to post photo’s follow the link I have attached below:
http://www.shipsofscale.com/sosforums/v ... f=62&t=895
I f your camera takes its pictures at a higher resolution, always set your pictures to ± 900 x 600 that way they will be between 200 and 300 Kb.
I will also ask Donnie to move your post to the correct area in the forum (Build Logs from Kits – Wood)
I have a few build logs at the moment, the main one is the HMS Endeavour (http://www.shipsofscale.com/sosforums/v ... f=52&t=718). I am also doing the Sovereign of the Seas, Mayflower and Marina II fishing trawler.
Hope this helps you, my personal email address is: e_hwall@iinet.net.au
(There is an underscore between the e and h (e_h)
Until next time.
Regards
Eric
User avatar
BETREMIEUX
Seaman
Seaman
Post by BETREMIEUX » Wed Dec 28, 2016 2:07 pm
Boujour Eric et Donnie
J'ai retrouvé mon sujet dans kit woob. Merci.
Je pense que la fonction photo est comprise!
Vous me direz si vous la voyez bien.
C'est une époque du montage du kit original que je vais montrer avec une suite de photos,
ensuite les modifications qui sont faites en prenant connaissance de la Cutty Sark, jusqu' à aujourd'hui ou il commence à reprendre forme.
Eric, vous vous exprimez très bien en français.
Daniel.
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Wed Dec 28, 2016 3:44 pm
Bonjour Eric and Donnie
I found my subject in kit wood. Thank you.
I think the photo function is included!
You will tell me if you see it well.
It is a time of the assembly of the original kit that I will show with a series of photos,
Then the changes that are made by reviewing the Cutty Sark, until today or it starts to take shape.
Eric, you speak very well in French.
Daniel.
Haha, thankyou Daniel but no I do not speak French, I used Google Translate (https://translate.google.com.au/) I find it very good !
I am glad that it is working for you.
Regards
Eric
Haha, merci Daniel mais non je ne parle pas français, j'ai utilisé Google Translate (https://translate.google.com.au/) Je le trouve très bien!
Je suis heureux que cela fonctionne pour vous.
Cordialement
Eric
User avatar
BETREMIEUX
Seaman
Seaman
Post by BETREMIEUX » Thu Dec 29, 2016 8:36 am
Hello,
Today I post some photos of the debut of my scale model.
In first, it's the integral kit of Del Prado.
I use also Google trad, I write english and control if is good in french.
Bye
General view / Vue d'ensemble
Dunette
Détail
Poop / Poupe
Gouvernail / Rudder
Pont vue de dessus / View from above
Détail
Début hauban / beginning stay
User avatar
BETREMIEUX
Seaman
Seaman
Post by BETREMIEUX » Sat Dec 31, 2016 9:11 am
Hello,
Secondly, I have some difficuties to continue, then I go on internet and search the answerds to my questions. I find the plans of GF Cambell on museum of Greenwhich. After i decided to modify the rigging with this plans.
Happy new yeard.
User avatar
BETREMIEUX
Seaman
Seaman
Post by BETREMIEUX » Sat Dec 31, 2016 9:13 am
Happy new year,
Daniel.
User avatar
Neophyte
Seaman
Seaman
Post by Neophyte » Sat Dec 31, 2016 10:25 am
Hello Daniel
Great model of a great lady of the seas.
Really like the mods.
Looking forward to seeing more.
:text-welcomewave:
Rick
I've reached that age where my brain went from "you probably shouldn't say that" to "what tha hey, let's see what happens". :cool:
User avatar
Neophyte
Seaman
Seaman
Post by Neophyte » Sat Dec 31, 2016 10:27 am
Happy New Year back at you.
PS:::: you speak better English than I do your language....... :handgestures-thumbup:
Rick
Post Reply
