Panart: San Felipe 1:75 Scale Build Log
Moderator: zoly99sask
User avatar
Donnie
Senoir Chief Petty Officer
Contact:
Re: Panart: San Felipe 1:75 Scale Build Log
Postby Donnie » Fri Jul 07, 2017 10:29 pm
Thank you Gary, Aussie, and undersea. I appreciate it very much. I went ahead and made a video on how I am making the post.
Enjoy.
I hope you all like it.
Donnie
Current Build Prep: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
No Guts, No Glory !
User avatar
Donnie
Contact:
Postby Donnie » Sat Jul 08, 2017 4:48 pm
For the front head railings, since they are multi-stepped railing, I chose to make a single post that will drive all the way through. In essence, it is a double post on a single cut dowel.
First image is post alone. Next is tapping it into place. The last image shows that things are very even and equally spaced. A template was made out of scrap dowel and measured before cutting on lathe. In this case, the dowel had to be flipped around and cut from each opposing end due to flexture.
No Guts, No Glory !
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Postby eric61 » Sat Jul 08, 2017 5:27 pm
Hi Donnie, great instructional video, thanks!
My mini lathe, manufactured in the sixties, unfortunatley does not have digital readout, the only way I can get that is to computerize it and rely on the stepper motors for the measurements.
Once again, great video.
Regards
Eric
Cook's Endeavour - current,
Sovereign of the Seas - current (deAgostini)
In queue: Marina II Fishing Boat by Artesania Latina
In queue: Mayflower by Model Shipways
"I was thinking then it all went blank!"
User avatar
Donnie
Contact:
Postby Donnie » Sun Jul 09, 2017 11:07 pm
Thank you all again for the nice comments. Well, this is it for the evening. Basically almost finished with front head railings.
No Guts, No Glory !
User avatar
Donnie
Contact:
Postby Donnie » Sun Jul 16, 2017 5:39 pm
This image below is an alignment block to make sure I have all the rails at the same height spacings. The height is 7mm.
The next image below show the cap rails. The box came with "half dowels". There are some brass figures that will be sitting on the half round dowels. Doesn't look right. It is interesting that the box art has the cap rails using plain walnut strips. Since none came with box to do this, I used a piece of walnut planking strips and cut it down the middle. Seems good to me.
A continuation of showing cap rail installment, then installing some support block stanctions and the end railings.
I do not have a good saw. The only one I have is just a hand saw with very fine teeth. Nothing wrong with it for rough cuts, but when I need a more precise right angle cut, the hand saw is not going to do it, even with the miter box. So, then I resorted to using the lathe - marked off the walnut block and chucked it up and used a parting tool. The lathe cut block off perfect right angle. (however, the railings are not quite 90 degrees, and a little shaping was required.
This image just shows me installing another block stanction. It is hard to get the glue into the tight spot, so, I just treenailed the block into position. This didn't take long as I am already setup to do these things anyways. Then the next just shows that I trimmed the treenail off flush.
The last set of images showing some final work on rails.
Thanks again for watching.
Donnie
No Guts, No Glory !
User avatar
Donnie
Contact:
Postby Donnie » Sun Jul 16, 2017 9:13 pm
Dry fitting some ornamentation before quitting for the evening.
No Guts, No Glory !
janos
Petty Officer Third Class
Postby janos » Tue Jul 18, 2017 4:05 am
Great work, Donnie!
Janos
User avatar
modelshipwright
Petty Officer Second Class
Contact:
Postby modelshipwright » Wed Jul 19, 2017 3:04 pm
It is looking mighty fine Donnie. I am looking forward to seeing more as you go along.
Bill
If it is worth doing, it is worth doing right.
Current build: Mantua Sergal bashed Sovereign of the Seas 1637
My Carving Book: Carving Ornamentation for Ship Models.
My website: http://www.carvingbook.weebly.com/
User avatar
Aussie048
Petty Officer First Class
Postby Aussie048 » Fri Jul 21, 2017 12:20 am
Donnie
I like the idea of the Lathe and the 4 jaw chuck for cutting of timber.
$350 for a 4 jaw chuck for mine. I think I will buy some brass tubing as a sleeve and use the 3 jaw chuck.
Cheers
Geoff
Current Build Link:-
Mamoli - USS Constitution
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
***Live , Listen and Learn***
Who is online
Users browsing this forum: No registered users and 1 guest
