Santa Maria - Mantua - scale 1:50 modified kit semi scratch
Moderators: Aussie048, zoly99sask
User avatar
Brian077
Petty Officer First Class
Re: Santa Maria - Mantua - scale 1:50 modified kit semi scratch
Post by Brian077 » Wed Aug 09, 2017 12:58 am
I love that wipe on poly, but its hard to get down here. Great job Zoly.
Current Build Link:-
ZHL - Xebec Le Requin
Future Build Link:-
H.M.S Enterprise 28 guns
User avatar
mtbediz1
Petty Officer Second Class
Post by mtbediz1 » Wed Aug 09, 2017 5:13 am
zoly99sask wrote:I applied a second coat of poly, actually the last one,not really visible but here it is.
Very nice Zoltan. How do you apply poly? By brush, airbrush or cotton cloth etc? Thanks.
Mustafa
User avatar
janos
Post by janos » Wed Aug 09, 2017 7:36 pm
Brian,
I just bought a satin wipe on poly at Bunnings. Not cheap though.
Janos
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Post by zoly99sask » Wed Aug 09, 2017 10:32 pm
Janos ,is that Minwax wipe on poly?
User avatar
Aussie048
Post by Aussie048 » Wed Aug 09, 2017 10:40 pm
Zoly
Unfortuantly it is not Minwax.
It is Feast Watson
Cheers
Geoff
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
User avatar
Brian077
Post by Brian077 » Wed Aug 09, 2017 10:53 pm
Janos and Geoff,
I was considering the Feast Watson oil based wipe on poly as an alternative because the Minwax has disappeared from the shelves at the local hardware stores down here.
Be interested in your feedback guys on how it compares.
Future Build Link:-
User avatar
janos
Post by janos » Wed Aug 09, 2017 11:36 pm
I bought the Feast & Watson one because the Minwax disappeared from the shelves (and it was much cheaper than F&W!). I have been using the F&W now on my SoS and I can't see any difference between the two (other than seeing red because of the price of it...). The first coat on SoS was still the old Minwax, but then (after much of it had been sanded off) as I wanted to apply the next coat I realized that it went thick and could not be used. Then I went to Mitre 10 when I bought the Minwax a while ago. There was nothing, so I went to Bunnings where I found the Feast and Watson for $33. As I applied the first coat of it, partially on top of the Minwax cote, nothing happened, they did not start fighting each other. Lucky I assume...
Actually I wanted to be 'clever' and as I opened the Minwax bottle I filled half of it into a separate container and sealed it, hoping that I can use it further than what was going to be opened-closed frequently. It did not work, it thickened up the same time as that one in the original bottle, which I was frequently opening. I imagine that the original bottle must have been filled up with Nitrogen or something similar to avoid contact with Oxygen.
Janos
User avatar
Brian077
Post by Brian077 » Thu Aug 10, 2017 12:55 am
Janos,
funny you say that about the Minwax. I had the same issue.
When I was using it varnishing my model, I was constantly opening and closing the cap and this caused the contents to congeal and go gluey. I had to throw a third of the can away.
Future Build Link:-
User avatar
Canoe21
Contact:
Post by Canoe21 » Tue Aug 15, 2017 9:53 am
Hello Zoltan
I kind of figured that on attaching your Channels but just wanted you to be aware of the problems they would cause if they broke loose later on in the Rigging.
Thar Poly that you ate using is it a gloss or a semi gloss finish, ENJOY.
Regards Lawrence
canoe21 { Lawrence }
PRESENT BUILD - http://www.shipsofscale.com/sosforums/v ... =59&t=1221 - GOLDEN HIND< Harold A. Underhill build plans, scale 1:60
Completed Build http://www.shipsofscale.com/sosforums/v ... =59&t=1172 HMS Bounty, scratch build, scale 1:60, using Amati build plans
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Post by zoly99sask » Tue Aug 15, 2017 10:00 am
Hello Lawrence ,the poly is satin ,no gloss at all,thanks for visiting my build log.
Post Reply
